Check the pedal box for noise, of strange feeling when pushing pedal down, if its a manual? Ive changed a few pedal boxes where the welds let go in the pedal box.
Hey guys,
Found this forum through PF and Google - looking for advice on what to look for and what goes wrong on the 97 model polos.
I am looking for a small-medium reliable econobox for daily duties.
I found a very cheap 97 Polo Manual, 170,000km that looks in pretty good shape, service history via a local mechanic as opposed to dealer. The only thing wrong that I have been told so far is the Drivers side window doesn't work (common issue I believe), but looking for any other advice / tips on things to look for.
I understand they want PULP - is 95RON Ok, or do they need 98 ?
What is the economy *really* like ??
I'm not after a rocketship, but as long as it keeps up with traffic and is not unbearably slow.
Any advice would be greatly appreciated..
Thanks
Jason
The gearbox is the weakest link. First Polo's came with a 1.1 engine and progressively got bigger until theu were 1.6. The gearbox never changed and was never made stronger so make sure yours doesn't make any noise.
To get a little bit more power remove the end of the air intake, the bit that has the thermo switch. It's very restrictive.
I also recomend cutting a couple of coils off the springs to lower the car and fitting some 14" alloy wheels with 185 x 60 x 14 tyres. Turns the handling from sloppy to tight and really nice through corners. Totally transforms the car into something more fun to drive.
It will run OK on 91 octane and if you keep it at 100 k's on the open road you should get low 6's per 100 k's on country drives.
Paul
1978 MK1 2.0 16v http://www.vwwatercooled.com.au/foru...-46488-70.html
1991 MK2 GTI 2.0 8v, white (RIP) and it's red replacement http://www.vwwatercooled.com.au/foru...gti-42078.html
1997 MK3 CL http://www.vwwatercooled.com.au/foru...ml#post1292061
2001 & 2002 Bora 4motion. http://www.vwwatercooled.com.au/foru...st-123823.html
Gearbox, Gearbox and more Gearbox... Thats why when you see them go at the auctions, if they are low mileage but have a manual gearbox they often still go for > 1k, where as if the same car comes up in auto, its 300-400
Check over the gearbox thoroughly, because when it fails the cheapest i have seen them for is about $1200 (camden GTI incidentally in sydney, he sold me mine) plus fitting etc, often easier to throw the car out and buy another one.
Also common is the throttle body. Its a hybrid cable / electronic item and the electronic side of it can fail which will exhibit a hunting idle and sometimes it will just die for no particular reason. Easily replaced of course, but they are not cheap (and done even ask VAG for a price), 2nd hand they're about $250, but dont bother with those, google around and there is a place in germany that sells brand new ones for about $200 (probably better now with the aud$$ exchange rate).
As for the elec window not working on the one you are looking at, probably the wiring has shorted out in the door. Unscrew the black door connector from the car with the door open and peel back the black rubber surround and check it out. I have forgotten which colour it is, but i'll crack mine open and have a look if you like.
Other common thing is central locking stops working. It's commonly the vacuum pump and easily replaced, or if its just one door, the vacuum chamber on the locking mechanism (had mine apart yesterday).
Economy is good on 98ron. I only run mine on 98 and as a guide I get 600+kms to a tank of urban / country driving. When running 91 i can appreciably notice the difference. Not so much in power, but certainly in economy with it getting 500-550. Is it worth the difference??? probably not, but i figure its so frugal anyway, the least i can do is give it decent fuel.
Speaking of gearbox, often the DKE which was fitted to our cars was not available when the old owners replaced them, so check out what it revs at at 100. Should be about 2,500-2,600. If it has had the 'city' gearbox fitted (i believe some of the 3 door models got it) it will rev at 3,000 or so. I have 2 polos, one with each of the difference gearboxes and i can say that the city one that while it revs higher on the freeway, its certainly punchier in and around town just screams a little on the fwy.
Good luck with it, these are really good little cars aside from the gearbox![]()
My Car(s): 2011 6R TSI Comfortline (Pepper Silver),
If you're in need of any 6n1 parts, odds are that I am going to have them (dismantling 2 at the moment)
Hi Pontiff,
There actually some gems of information on the Polo in that post. Where is the vacuum pump located on the Polo?
Cheers,
Steve
The pump is located in the boot on the drivers side where the first aid kit should be (neither of mine have one).. here is a pic. Its made by Hella.
If you need any parts cheap let me know. I'm wreaking my 97 Polo.
Paul
Hi Paul, Pontiff,
I'm just wondering how you tell if it's the vacuum pump causing issues with the central locking. I really should try and find a workshop manual I guess. Paul, if you have a working Vacuum pump, PM me, and we can strike up a deal. Otherwise, any ideas on finding them, or is VAG the only option?
Cheers,
Steve
If it is just one door, its either the vacuum box on the locking mechanism or the vacuum hose to the door. If all doors dont work then its probably the pump, but could be the hose running out of the boot.
Either way i would not worry too much about it, its not going to be expensive to fix, just somewhat trial and error.
Thanks for the tips here and also the PM's received, I really appreciate it.
I went and had a look at on Sunday arvo and I now see why it was so cheap.
There was rust all around the front screen and in the roof beside the body runners
The body was in reasonable condition - few bumps and scratches.
The interior window switches were hanging out (an attempt to repair the faulty drivers one I suspect) but there was evidence of other dash panels being removed and replaced as it had more rattles than a baby shop. At this stage, I made my mind up that it wasn;t for me, - but still wanted to drive it as it always pays to drive as many as you can to see what the good ones feel like vs the bad ones... right..?
It certainly drove well enough, the gearbox felt fine, actually, the clutch and gearbox felt pretty good after everyone waswarning me about them... but unfortunately for me - the rust was just far too advanced to justify buying it
Thanks again for the tips..
For anyone interested - It's white, Rego'd until 8/8/11 and located in Belrose, (NSW) - The bloke who owns it is a surfie dude who has been offered a good job in the mines, so it has to go. It's lived most of it's life on the Northern Beaches of Sydney, hence the rust. He is asking $1500 ono - so if anyone i9s interested - PM me and I'll give you the mobile number of the owners mate who is selling it for him now that he is away .
