Originally Posted by
Gigitt
if it is manual... then it's possibly fubar.
the manual box is weak and I've heard it is a common problem - basically rebuilding it is not worth it as one of the bearing housings deforms or wears the case out or something and cannot be fixed - hence the gear problems.
There was a dismantled gearbox on Ebay around 12 months ago where all the parts were supposed to be OK but it appeared that a bearing had spun in the housing.
The 085 gearbox has the gear selector shaft low down in the box & when the seal leaks the oil comes out. A lot of people, if unaware of this, take no notice of an oil leak & keep on driving until the box is ruined. When I bought my 6N2 there was a leak & when I was replacing the seal I noticed someone had been there before so I think the seal has a limited life & needs to be checked often.
How much is cheap for this Polo?I don't think a good running '97 would be worth much so it's probably not worth all the work & hassle. Our local wrecker wants $1600 for a s/h box & then there's the fitting. From my experience, when I installed a new clutch, it's not an easy job because room is very tight so paying someone to fit it will charge accordingly.
Numerous Mk1 Golf diesels
