Page 12 of 16 FirstFirst ... 21011121314 ... LastLast
Results 111 to 120 of 154
Thread: My long term project, 1.8T 6N2
  1. #111
    Jan 2012
    Bentleigh East, Melbourne, Vic
    I am loving this thread...car looking good.
    Polo 9n3 GTI
  2. #112
    Aug 2007
    Minor update, pretty busy at the moment, so have had little time really. That will change. Anyway i was set to order an 034 manifold but had to put funds elswhere for now, so got my Dad sending over a BAM manifold so i can have my throttle body on the pass side as drivers side is way too tight with the AGU set up and i might also be rethinking the mounting oin th right hand side, left is set, drivers is a pain. Stay tuned for that. Few other goodies ordered from back home, but will keep them under wraps for now.
    All for now
    Jmac
    Alba European
  3. #113
    Aug 2007
    Just a minor one again after all its a long termer, the mount phase is nightmare as im so against notching the chassis, good freinds back in the motherland have done it that way but im sure ill manage without but with that said thats whats making it a nightmare, now the MK3 mount idea is shelved, im now gonna have and adjustable mount on the drivers side with a Skoda Fabia TDI Console bracket and looks like a Mk3 gearbox mount will be my engine mount!!! yep fun
    Ill keep you updated of course, excited about the break at xmas.
    Jmac
    Alba European
  4. #114
    Jun 2007
    Eastern Suburbs Melbourne
    Geez, lotsa fiddling around there.
    i like volkswagens
  5. #115
    Time for some pix please.
  6. #116
    Aug 2007
    Dont worry mate more pics a commin!! ive waited since Nov for my inlet to arrive!! My mother posted it Nov from Scotland and its only just got here, only one bracket for the engone which will be a Skoda Fabia diesel one, with a little fettle itll be seet, then ill be measuring up the drivedshast then the wiring begins which is my favorite part. So far im not notching the chassis!!!!! so far!!!!
    Stay tuned
    Jmac
    Alba European
  7. #117
    Aug 2007
    Just a minor update, the manifold did eventually arrive , it was posted November!!.Its a BAM engine manifold so the throttle body can be mounted over gearbox, it was too tight drivers side. Bam isnt bigport though so i either have to cut the runners off and join up with the Bam tank or use adapter gasket, i got next to no room for spacer so might be manifold fabrication. Anyway Engine mount ordered and will be using the fabia diesel one as before mentioned and turning a Mk3 gearbox mount upside down with another plate on an eccentric so i can move stuff around till im happy with posi. Im seeing now that a left hand drive one would have been awesome as there is tons of room pass side for the master cyl and bugger all on the drivers side, its so close to the tappet cover. That will have to be addressed because im sure there will be a fair bit of flex on the engine so thinking about that before i commit to its final posi. Ive Had zero time of late but have been back in the shed and its on again, must admit ive been close to ditching it but would kick myself so dont care how long it takes now
    Jmac
    Alba European
  8. #118
    Whenever you get tired of working on it just imagine how shi**y you will be in a few years time without it.
    And make yourself a good cup of coffee. Everything looks better with a hot cup in your hand.
    Cheers and thanks for the updates.
    Paul
  9. #119
    Camden, Sydney
    Just come across this Jimmy. Looks like you been having fun whilst I have been away. Seems like you have addressed most of the issues. You could consider a late polo GTI inlet manifold which comes out drivers side but straight not kinked.
    Should be a weapon when it's done.
  10. #120
    Aug 2007
    Yeah mate loads of fun, and ill have more time soon as you will probably read on here too. Anyway, the 9N3 from the BJX is small port pal, the AGU is bigport and i dont really have room to use adapter plates, looks like ill be using AGU runners and BAM tank, the throttle coming out at the right spot. Dont worry progress soon. Few cars i had now shifted along with more time coming should be sweet, just to add im using the recaros in my VR6 now, so im in the hunt for another set or maybe even a set of seats from a 9N3
    Jmac
    Alba European
