Results 1 to 5 of 5
Thread: Idle issues
    Apr 2008
    Blacktown NSW
    Idle issues
    Hoping someone here will have a solution,
    Idling the car today whilst warming up, I revved it up to about 1800rpm but the idle stayed there even though I had taken my foot off the accelerator.
    It only stayed at 1800rpm for a few seconds, but on it's way back down the engine spluttered but then ran smooth again.
    Any ideas?
    Thanks
    Jun 2008
    Emerald, Vic
    Quote Originally Posted by parraeel View Post
    Any ideas?
    Thanks
    could be a sticking throttle cable, so check that, else it will most likely be the throttle body. they are a hybrid electronic/manual unit that is not uncommon to fail in the manner you mention (along with a few other common faults)
    My Car(s): 2011 6R TSI Comfortline (Pepper Silver),
    If you're in need of any 6n1 parts, odds are that I am going to have them (dismantling 2 at the moment)
    Aug 2007
    Ive got no doubt if you run a scan on that it will have codes if the throttle body is playing up, unfortunately they are a but problematic. If you try to source one there is a couple of options depending on the transmission you have.
    Good luck
    Jmac
    ---------- Post added at 07:29 AM ---------- Previous post was at 07:27 AM ----------
    Good luck
    Jmac
    Alba European
    Apr 2008
    Blacktown NSW
    Thanks for the replies.
    I was thinking throttle position sensor, which is on the throttle body anyway, so I will use that as a starting point.
    Jun 2011
    sydney
    Id get the throttle body cleaned and then basic set. If fault persists replace it.
