Waterish black stuff is water
Manual or auto? When cold an auto will idle about 900-950 or so until warm then go down to 600 or so. A manual will idle at I think the setting is 870.
Throttle body would be my first check, clean it and if you have a vagcom (or access to one), then run the throttle body reset/alignment which will step through the range of motion and tell you if the electronic side of it (for things like idle) is working..
They are not uncommon to fail so its a good start
Well done on the purchase too... The open air models are nice.. Just keep that roof in tip top shape as they are not cheap to replace and also keep the guides lubed as motors are not cheap either
My Car(s): 2011 6R TSI Comfortline (Pepper Silver),
If you're in need of any 6n1 parts, odds are that I am going to have them (dismantling 2 at the moment)
