Results 1 to 10 of 16
Thread: Few questions!
    Feb 2013
    doreen,vic
    Few questions!
    Hey guys I just purchased a 97 polo open air! Now I've searched around and haven't found a sure answer,so......on a cold start the idle sits around 780-820 and it shutters abit(not under acceleration tho) until warm?throttle body dirty? And the exhaust leaks a waterish black stuff! Not fuel or anything, cat could be ruined or more serious? Or a by product from a dirty throttle? Any help appreciated.
    Cheers guys
    Gav
    Jun 2008
    Emerald, Vic
    Waterish black stuff is water
    Manual or auto? When cold an auto will idle about 900-950 or so until warm then go down to 600 or so. A manual will idle at I think the setting is 870.
    Throttle body would be my first check, clean it and if you have a vagcom (or access to one), then run the throttle body reset/alignment which will step through the range of motion and tell you if the electronic side of it (for things like idle) is working..
    They are not uncommon to fail so its a good start
    Well done on the purchase too... The open air models are nice.. Just keep that roof in tip top shape as they are not cheap to replace and also keep the guides lubed as motors are not cheap either
    My Car(s): 2011 6R TSI Comfortline (Pepper Silver),
    If you're in need of any 6n1 parts, odds are that I am going to have them (dismantling 2 at the moment)
    Feb 2013
    doreen,vic
    Manual all the way! Just cleaned out the throttle and did a reset, idle fine then went back to 780-820 so I've ordered a coolant temp sensor as I've read that's a common problem so see how that goes. I'll be doing a "build" thread soon once I've got it registered and in its daily use!
    Jun 2008
    Emerald, Vic
    Manual is better I agree . Hope u didn't pay too much? It will fail at some stage, get yourself one of these too
    http://m.ebay.com.au/itm?itemId=191008215835
    Contains many bits that are common, thermostat and housing as well as the coolant flange... It's cheap all things considered
    Feb 2013
    doreen,vic
    Got the car for under $1000! One owner, all service history and original receipt from purchase at the dealer!
    Jun 2008
    Emerald, Vic
    Great price! Where was that advertised? How many kms?
    Feb 2013
    doreen,vic
    It was on gumtree lol has 166k's
    Jun 2008
    Emerald, Vic
    Good stuff! 166k is good... Just keep an eye on the gearbox, they are not known for their reliability
    Feb 2013
    doreen,vic
    Yeah I've heard that the leak at the top of the box and people miss it then it ruins the bearings
    Feb 2013
    doreen,vic
    Back to what I was asking lol black waterish stuff is nothing to be concerned about?
