No vacuum leaks?
Hi again,
I have a 6N2 GTi AVY Engine. When engine is cold, I give the first gear and drive off, but it's having a cutting feeling... It will last for 1 minute or so. Its very light. When warm it doesnt happen. When engine is warm and at idle, the engine shakes and even when I try to pull over with the first gear, I rev it a bit and it feels sluggish and has a engine shaking feeling.
Hope that someone can understand the above...
Much help appreciated.
No vacuum leaks?
My Car(s): 2011 6R TSI Comfortline (Pepper Silver),
If you're in need of any 6n1 parts, odds are that I am going to have them (dismantling 2 at the moment)
Where are the Vacuum Pipes?
Thanks.
How do I check for Vacuum Leaks? All it has is one hose from the brake servo to the inlet manifold and this hose seems to be fine. It has a valve too.
Should I replace it, maybe the Valve is stuck?
Thanks.
How is the catalyst, id suggest you take it to a tech and test the engine with a vac gauge before throwing more parts at it. At the same time be checking all the basics first, really have to , its such an open question where you might get lots of suggestions and get nowhere. Really needs the fundamentals tested. Then move to tier 2 diagnostics
My opinon
Jmac
Alba European
Thanks for your reply. The CAT is fine. Will do a VAC Test. Will first replace the Vacuum hose from the Brake Servo which leads to the Intake Manifold. There was a recall on this hose.
If I still have this problem, I will do a VAC Test.
Thanks for your reply. I changed the Vacuum Hose from the brake servo to the inlet manifold. The old one had cracks in the pipe, it was blocked and the valve was stuck. Replaced it and it seems fine for now. Engine doesnt knock and doesnt shake anymore for now... I hope it will remain like this.
Thanks for the help.
