If the 10th digit of your VIN is the letter "V" (indicating model year 1997), use part number 6N0 698 151 C.
Hi all,
I need a technical advice, please. I want to replace the front brake pads of Polo 6N.
Check in ETKA and found out that there are two type of brakes pad:
1. 6N0 698 151C
2. 867 698 151
My question are:
Was Polo 6N1 fitted with 2 different type Calipers? Therefore before buying the brake pads, I need to know which Caliper that I am using.
Was it the disc rotor (vented or solid) that will determine which pads to be used?
Are these pads interchangeable? i.e. I can use either 6N0698151C or 867 698 151.
I called a VW part department, without getting any exact determination. They suggest to bring a sample of the pads.
Thank you very much in advance for the information and time.
Iwan
Polo 6N - 1997
