Hi Pontiff,
As I only got this car around 2 months ago, silly me never noticed the huge crack in the original breather hose, as it was on the underside which I could not see, so I imagined as it was like this for a while, that there was a lot of moisture entering inside and causing it to mix with the oil and cause this (mayo), I checked the top of the hose today and looked in the air box, still clean as a whistle, so again the neglect of this bad hose (originally fitted) that was cracked was the culprit of this mayo.
Oil levels have also been good.
Thanks for your nice words jets!
Now I have a bit of play with the clutch pedal and I am hoping it is not the pedal box, otherwise I am in for some fun!
