Update after 3yrs:
Replaced a gear linkage today, result means cannot go into 1,2, 5 and reverse. Easy fix. Might do a write up soon.
As I was doing this, noticed the hose has cracked bad on the bottom, so for this in future, I recommend to go OEM! Will call VW on Monday for original breather hose.
Go Tiges!!!!
Update after 3 yrs from previous 2019 update:
Hose is still fine, and removed breather box while doing some other work on car, and is still clean, as mentioned stick with OEM when ever dealing with the breather pipe.
Not seeing much 6N2 these days on the road, I do look after mine a lot though (216000km so far)
