Results 1 to 4 of 4
Thread: ABS and handbrake lights on
    Apr 2014
    Adelaide South
    howdy,
    hey folks this is my 1st post here been away on military tour back home now
    i recently replaced the abs power pump on my polo(6N2) however, to cut long story short after clearing the error cords
    2 lights keep flashing on the dash.handbrake warning light plus ABS light
    A trip to the auto shop had me rescan for more errors using VAG COM
    We discovered the rear wheel speed sensor was faulty probably with dust.it was cleaned and replaced
    The 2 lights are still flashing on the dash board. i was advised to find help and have the ABS re calibrated
    Seeking help and advice on whether i can recalibrate a 6N2 abs system and with what scan tool
    i have attached some photos showing the lights on the dash
    Thank you
    bambino
    Attached Thumbnails Attached Thumbnails ABS and handbrake lights on-new-abs-pump-jpg   ABS and handbrake lights on-flashing-lights-engine-idling-jpg
    ABS and handbrake lights on-vagcom-jpg   ABS and handbrake lights on-flashing-lights-dash-jpg
    A scan with a real VCDS lead might help. Purely guess work otherwise.
    It has brake fluid doesn't it?
    Apr 2014
    Adelaide South
    i had the fluid flushed out using brake bleeder topped up with Bosch Barke fluid cost me an arm and a leg
    had the car scanned using 3 diffrent scan tool; Launch Autoboss and VCDS on a laptop.All reported the same error code
    the VCDS cleared all codes however the lights still flash on the dash
    Bambino
    VW POLO AHW 1.4 16v
    YR 2000
    Quote Originally Posted by BambinoPolo2k View Post
    Bambino
    Which was?
