Originally Posted by
AALocksmiths
I have had a lot of VW cars with immo faults caused to faults in the cluster but mostly in hotter weather.
In the ECU you should have a fault like "17978 Engine start blocked by immo" and in the instrument cluster would be "01128 immo pickup coil" and "01176 key".
If it is a cluster fault most of the time I can repair these.
If the immo is the same as the ones in the 6n1's you could just try and bypass it to test with. You can get them from ebay, or i have a few here. i actually have an immo from a 6n2 i could look at if you need.
My Car(s): 2011 6R TSI Comfortline (Pepper Silver),
If you're in need of any 6n1 parts, odds are that I am going to have them (dismantling 2 at the moment)
