Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: 6N2 fault codes
    May 2013
    Central Queensland
    Heya. Update***
    I have the car in the vw dealership and its looking like its ECU issues.
    Powers going im but not out. They cant work out why at this stage and arnt 100% sure they will.
    Now my question is can i get a second hand ECU? They said something about having to change a heap of other bits if i tryed that????
    Really want to fix the car but putting a brand new ECU in just isnt worth that cars value.
    Thanks for you input
    Steff.
    Yes a used ECU can be adapted but the dealer will try sell you a new immo/ cluster and ECU.
    All they would need to do is read the coding in your ECU, plug in the new/ replacement ECU and adapt it using the PIN then change the coding to match your old ECU.
    Do you know the part number from your ECU?
    May 2006
    Adelaide South Australia
    When I had my 6N2 I started to have immobilizer fault show & in my case the battery would crank OK but had too much voltage drop.
    The fix in my case was a new battery. Problem solved.
    Numerous Mk1 Golf diesels
    May 2013
    Central Queensland
    They changed the coil/ariel on the barrel and still nothing the systems not reading the key so they cant even start there computer to see whats wrong. So now they are blaming the immo is the problem. I've told them to stop as the cost is getting to high.
    The cars a fair way from me at presant so i cant get the numbers of the ECU/immo (
    Starting to think it mite be all over
    May 2013
    Central Queensland
    Finally got the car back to day and when i can work out how to attach a photo of the ECU i will. So many different numbers so im not sure which ones your after.
    I do know that there is no spark and no pulse but it has power to the fuel pump which im lead to believe its more likly not the immo as that shuts the pump down to?
    May 2013
    Central Queensland
    6N2 fault codes-image-jpg hope this works
    Jun 2008
    Emerald, Vic
    not sure on the 6n2 what it does, but either way if it were the immo it would be logging faults, so if you are not seeing coil / immo related faults i would indeed look elsewhere.
    not sure on the 6n2 (only had one through the officer wreckers ) but do they have a hall sensor on them? that can fail which would exhibit what you are seeing (been there done that).. can you see if there is spark coming from the actual coil itself?
    My Car(s): 2011 6R TSI Comfortline (Pepper Silver),
    If you're in need of any 6n1 parts, odds are that I am going to have them (dismantling 2 at the moment)
    May 2013
    Central Queensland
    no idea if it has a hall sensor , ill look into that, i do know it doesn't have spark from the coil...
