Small update, new (old) brakes arrived, new rotors sorted, new front shocks shortened by 25mm, need to sort some springs still, going to find the dimensions of some aftermarket ones in the UK and get some matched or made.
New rotors are the same diameter as old, but vented sos shouldn't fade as quickly.
Old caliper, pads are around the size of a matchboxadd to that the lack of power assistance and they were quite entertaining.
New caliper ,as fitted to MK2 GTi's and similar.
Old monroe shock (massive heat marks on the piston) vs NOS Gabriel shortened 25mm ( i will put something better in when i sort some springs.)
I cut 2 coils off the std springs and managed to lower the car by an enormous 6mmNot even picworthy...
Well it settled a little and is now down around 20mm, looks a little better, will have to do for the time being.
In other news it goes in for a WOF on thursday, hopefully the list isn't too long. Also found out that it doesn't like 91, coughs splutters and stalls all over the show. Swapped to a bigger OMP steering wheel, think i might sell the Nardi one, it's all of 300mm diameter, just a little too small for this one i think.
Made a blinging oil catch tank, cost a grand total of around $16 and looks like it's worth at least $20 :mrgreen:
WOF .... fail
Needs a new passenger seatbelt, wheel bearing play fixed, and rear brakes adjusting, not too bad for 6 years with no wof.
Should be wofed before xmas..
woohoo, now fully street legal.
More pics of mildly improved ride height when it stops raining...
Well i've been driving it as much as possible, been fiddling with the carbs to get it running better, now does around 20 MPG whereas before it was more like 10 MPG. Is running considerably better too (except for idle, just does not want to idle well.
Have made a new manifold up for it, thanks to Slayer00 cutting me a sweet flange, came out real nice and was super quick and a good price, well recommended.
I was too excited to take pictures of the flange before welding, but you get the idea.
Close up of my welding, need a new torch so that i can do it in one pass, hell, need a new welder too with HF start, and foot control, would make the welds much neater.
Waiting on a new waterpump to arrive from Pomgolia, managed to buy it when the NZD was worth something, then i'll pull the head portmatch the new IM, do the headgasket, give the cooling system a good flush out, pull the gearbox, check that the clutch will handle some track abuse and then clean it all up and put it all back together with new gaskets and fluids.
