Results 11 to 20 of 33
Thread: Xenon Lamps - How much?
    Oct 2006
    i can pass on my discounts if anybodies interested, iso approved kits and are extremely good quality (have used a few now) around the $300 mark for any h1/h3/h7/h4 etc, hi/low kits i cant remember.
    Aug 2006
    Skye, Victoria
    Quote Originally Posted by dilbert_rocks View Post
    Phew! I was pretty certain that's what u intended.
    I'm guessing that the kit doesn't come with a cleaning mechanism for Lo beam as per ADR? I think there is another thread somewhere that talks about what is legal to retrofit in Oz.
    No it doesnt, but i dont think i've EVER seen a retrofit with the washers on it unless it was a standard fit to the car (i.e saab)
    Oct 2006
    problem with adr rules theres loop holes everywhere and no definate answers on anything if you query things.
    stuff is TUV approved and superceeds australian standards yet ADR / RTA has problems with that? its freakin stupid
    Aug 2006
    Skye, Victoria
    I was under the impression that the cleaner thing was more for countrys with snow? the more important thing i think for hid's is the self leveling system.....
    May 2007
    Moonee Ponds
    I was under the impression that HID/Xenon bulb's required a high levels of voltage and special regulators. So I always thought that you had to replace the entire assembly of the lighting system.
    I didn't think it was possible to just replace the bulb's ?
    Thanks.
    Feb 2007
    Bunyip, Victoria
    Quote Originally Posted by qsilverza View Post
    Thanks.
    you are right. anyone selling just bulbs that claim to be xenon are lying. Xenon requires a ballast (choke) to ignight the gas in the bulb to start the reaction. once started, they run the same current and voltage as a normal globe.
    May 2007
    Moonee Ponds
    Do you know much about the color temp's and as to which one gives the best all round light for driving ?
    Feb 2007
    Bunyip, Victoria
    the lower temps are accualy better for vision. these may not be as blue as some people like, but offer the best projection and clearity
    May 2007
    Moonee Ponds
    So how low are we talking ? 4300 K ? 6000 K?
    Feb 2007
    Bunyip, Victoria
    4300k is white, 6000k is very blue. the lower the k the less blue the light will be, if you can get a good balance between yellow (stock), white and blue, then you will have a very good light.
    In fact, the stock yellow globes (halogen) are often better than the white globes, as far as projection. the xenon will out project the yellow globes, and if you stick to the lower end of the availible temps, you will have very good light.
