Nope, but I have a few low kms 02a boxes![]()
Does any body know of a good repairer/reco for an 02A trans in Melb ?
what sort of dollars would u want for a decent 02A?
Be sure you get a VR6 one Tim as the housings are different to the 4cylinder ones.
Have you got a mk3 16v one Loon I may want one once I've done some maths on ratios.
Send it to Tassie and I'll do it.Originally Posted by aussieg60
Some how a gear has jammed against this shaft as shown in the photo. I took a photo through the drive shaft flange hole. I have seperated the trans from the engine. When I put it in gear thats what had happened, it got jammed. Im not sure what to do, is it a complete overhaul ? How could the gear move ?
I have 3 boxes. Codes are ata agc and csf. They are for 4 cylinders not VR6 and have hydraulic clutches. $1000 each.
thats a pretty wierd problem. wouldnt think the gear could just move out of postion like that. is this out of a vr6 ?
No, not a Vr6. Its from a G60 (ATA). The box has been sitting for some time, with no oil. I used to crank it round in neutral when it was attached to the engine.
You would be looking at the diff going by your description .
Means a stripdown.![]()
