Results 1 to 10 of 10
Thread: Transmission 02A repairer/rebuild in Melb ?
    Oct 2005
    Dandenong North, Vic
    Does any body know of a good repairer/reco for an 02A trans in Melb ?
    Camden, Sydney
    Nope, but I have a few low kms 02a boxes
    Point Cook, Vic
    what sort of dollars would u want for a decent 02A?
    Golfwise Guest
    02As
    Be sure you get a VR6 one Tim as the housings are different to the 4cylinder ones.
    Have you got a mk3 16v one Loon I may want one once I've done some maths on ratios.
    Golfwise Guest
    Re: Transmission 02A repairer/rebuild in Melb ?
    Quote Originally Posted by aussieg60
    Send it to Tassie and I'll do it.
    Oct 2005
    Some how a gear has jammed against this shaft as shown in the photo. I took a photo through the drive shaft flange hole. I have seperated the trans from the engine. When I put it in gear thats what had happened, it got jammed. Im not sure what to do, is it a complete overhaul ? How could the gear move ?
    Camden, Sydney
    I have 3 boxes. Codes are ata agc and csf. They are for 4 cylinders not VR6 and have hydraulic clutches. $1000 each.
    thats a pretty wierd problem. wouldnt think the gear could just move out of postion like that. is this out of a vr6 ?
    Oct 2005
    No, not a Vr6. Its from a G60 (ATA). The box has been sitting for some time, with no oil. I used to crank it round in neutral when it was attached to the engine.
    Golfwise Guest
    02a gearbox
    You would be looking at the diff going by your description .
    Means a stripdown.
Similar Threads
  1. melb day cruise sunday 21st may
    By WABIT in forum Das Social Club (Meets and Events)
    Last Post: 22-05-2006, 09:07 AM
  2. Melb - wanted - turbo mk 1/2
    By worm in forum Mk1 Golf
    Last Post: 09-12-2005, 03:55 PM
