Results 1 to 5 of 5
Thread: Recommended Workshop for DSG repair (likely clutch replacement) in Sydney North-West?
    Sep 2010
    Know of any recommended places to have a proper diagnosis and repair for the DQ250 in my R36? Otherwise will just take it to my usual workshop (Eurowerke).
    Have the exact same issue as here:
    DSG Problem, Car won't go into reverse
    '18 MY18.5 MK3.5 Octavia vRS245
    Previous - 2015 MY16 MK7 R, 2010 MY10 R36 DSG, 2010 MK6 Golf GTI DSG // APR Stage 2, 2006 MK5 Jetta TFSI DSG // Revo Stage 2, 2006 MK5 Golf GTI Manual
    Auto Trans Australia do a lot of the work for VW and are considered the best in the biz in NSW.
    Can't say you have the 'exact' same issue unless you've had it properly diagnosed. There are many different ways that a DSG can 'fail'.
    If you have VCDS or OBD11, what are the exact fault codes logged?
    Sep 2010
    Fault code from VCDS -
    1 Fault Found:
    19143 - Unexpected / Implausible Mechanical Gear Disengagement
    P2711 - 004 - - Intermittent
    Freeze Frame:
    Fault Status: 00100100
    Fault Priority: 0
    Fault Frequency: 255
    Reset counter: 40
    Mileage: 240999 km
    Time Indication: 0
    Date: 2015.11.13
    Time: 18:37:07
    Could be mechatronics or clutches.
    Given the mileage if the clutches haven't been done, and you have an AL revision or later mecha I'd probably lean towards clutches. once gearbox is out to replace the clutches the mecha can be inspected.
    Aug 2021
    sydney
    I haven't had DSG issues before although my Touareg is hard to work on as it's the V10 and the engine bay is really compact, I always take it and my Polo to Sams automotive in Five Dock, never had an issue with them.
