dont see a problem with this.you are not bagging anyone and you are just posting the quotes you got over the telephone.
there has been worse written here.
Firstly this is unbiased fact.....Moderators feel free to remove this if you think we'll get sued...
My mk2 golf requires front wheel bearings.
First I rang Volkspower, got a quote of $600.....
Second I rang Volksaffair, got a quote of $360....
Thirdly I rang South Yarra VW 'service department' they took my name and number 3 days ago and haven't called back
Finally I rang Volkwerke and will be having my front wheel bearings done for $300.
mk2 GTi 16v
Corrado G60
Hmmmm
I have been to many places to get my VR6 fixed.
I will say, I would pay the money to have Volkspower do it
Get my drift lol
Touchy subject
MODS- TOO MANY
I do most of the stuff myself but don't you need a special grease packing tool for front wheel bearings?
mk2 GTi 16v
Corrado G60
im pretty sure that you can get away with a largish syringe (less needle of course).
$600!. That's daylight robbery. No offence to anyone. Just alittle steep.
I don't reckon a VW dealer would even charge that.
$300 right on the money if everything goes to plan.
It take's me roughly three hour's to do this job & that incl's. making an hour round trip into town to use a press. That's just taking my time too & not rushing it.
So, two hour's labour + part's & the last set of bearing's cost me just under $100 (trade) from Rob Hamilton bearing.
Easiest way to do this job is to remove the whole strut.
Undo the tie-rod end, lower ball joint(this can be tricky to break the ball joint seat), drive shaft nut & top strut.
This way, youdon't need a wheel alignment.
Then you need to find & use a good hydraulic press.
Remove/press out the driveshaft hub, remove the circlip's & press out the old bearing.
Sometimes the inner bearing race can come out with the driveshaft hub & can be a pain to remove from the hub!
Press in the new bearing into the original postion, refit the circlip's & press in the driveshaft hub & then re-install the strut.
Geez Sean wasnt wrong when he said you know everything about VW's!!
If you do it yourself, got a hydraulic press at work you can come in to use on a weekend.
Just saw the date on the post, I'm prob a bit to late
MK2 GTI G60
Hate to say it, but I found similar finds to yours.
Dean is a great bloke though ! Be aware, Volksaffair did some work for me and did not use OEM parts.
