I'll be keen to see the results of these... I am not satisfied with my current bulbs.
Hi all,
I've just ordered a set of Philips X-Treme Power H4s, a set of Philips Premium H3s and received a free set of W5W Parkers.
I've then used a voucher code (AYSCX1729) to get a 10% discount.
The whole lot will be delivered to my door for less than AUD$65. Considering my local SuperCheap/Repco wanted $80 for the H4s, that's a bargain!
Nothing to see here...
'03 Bora V6 4motion ~ CC Flash ~ Neuspeed F&R ARB ~ .:R optioned - Bilsteins,Springs,shifter,steering ~ Tyrol Brake kit ~ EVOMS CAI
Parts for sale http://www.vwwatercooled.com.au/foru...ff-102387.html
Ooops, just realised from the thread title http://www.powerbulbs.com/![]()
Are these the brightest/best coverage out of the Philips range?
Yes, the X-treme (+80) globes are rated by Philips as producing the most light of all their std wattage globes. The next best are their +50 globes (I found them nearly as good as the +80, but not quite). Note that the +80 are NOT 80% better, more like 30% in my case.
They are a lot better than the so called hyperwhite or blue/white globes that ahave a blue coating on the glass (this actually reduces light output).
You should also be aware that all the increased output globes (+30, +50, +80) have a reduced life (ie they burn out filaments a bit quicker than std globes). This isn't enough to stop me using them, but I'm aware they won't last as long as the normal globes (the old story - "no free lunch"), so I carry spare globes in the glovebox.
If you want some decent, independent info about automative lighting, try Daniel Stern's lighting web site (he's the ackowledged lighting guru) :
http://www.danielsternlighting.com/t...lbs/bulbs.html
Haha, I forgot to actually include the URL, sorry.
http://www.powerbulbs.co.uk also works for them (that's the URL I used, but I doubt it matters).
Thanks for the info, have ordered a pair.
