Thanks for the info on the ECU Mark. So if you think that perhaps the existing Viezu tune that is on the hand controller might work once the new ECU has been installed and coded i might give it a try. Hopefully it will just time out if there is a problem and not corrupt the ECU or something?!?!
I have the errors on a VCDS scan at home that i can post up tonight if you are interested. There were a bunch of communication errors and the P-R-N-D lights on the MFD were flashing. Engine would crank but wouldnt start. Was fine one minute and dead the next....and then it worked again, car started, he drove home which was a few minutes away and then the car never started again after that.
