A few people have with Mk6 GTI's have done the XDL change from vwgolf.net and reported that the car feels different when cornering. But i havent seen or heard of point 2 that you have raised.
Whilst perusing a list of popular MkVI VCDS tweaks on golfmk6.com, I came across a couple of more recent discoveries that haven't been discussed over here before (that I recall):
Electronic Differential Lock (XDS) Strength
XDS is the electronic differential lock. On higher HP models (Scirocco R), this is set to 2, whereas the default on the GTI is 0. At 2, the system is more aggressive at applying brake pressure to the inside/slipping tyre.
XDS and Brake Assist Settings
Torque Steer Compensation (TSC)
Using the Steering Assist controller (not the brakes), TSC will help prevent torque steer on tuned cars. A TSC of 1 is used by default in higher HP FWD VW models like the VR6 FWD Passat.
VAG-COM — Torque Steer Compensation (update: it works!)
The latter tweak in particular sounds very interesting. To quote from that last thread:
Originally Posted by GolfMk6.com memberI haven't verified that these settings apply and/or take on Australian-spec GTIs, but if they do... sounds promising!Originally Posted by Another GolfMk6.com member
Would the TSC tweak work for tuned 118 TSI's? Obviously we don't have XDL.
I know this is a golf forum but I have done the XDL tweak on my Polo GTI and it is very noticeable compared to stock. The torque steer control is an odd one though because in my polo I very rarely get torque steer, what I do get though is the feeling of a locked front diff and when accelerating hard from a standstill, wherever the wheel is pointing, it feels tight when trying to move it from its position. I wonder if this is pre-programmed onthe polo...
I've had TS once or twice when TC was turned off
Very curious about being able to "dial up" the XDL... Be nice to tame that inside wheel spinning, a little further.
Gotta wait for my new clutch pack to be installed and have APR reloaded first
I had problems with ineffective XDL on my MY11 vRS Octavia, so wound it up with VCDS to setting 2, and it made bugger all difference. It still spins quite a few revolutions of the inside front wheel before there's any semblance of braking, but even then, it still allows a significant amount of wheelspin.
Redline3345 MY11 Octavia vRS Wagon TSI DSG | Brilliant Silver | Milltek cat back exhaust | Bilstein PSS10 | TSR Panorama | Remsa | Leather | Sunroof | Towbar | Front Sensors | Boot Protector | Xenons | Corner Fogs | Alarm | Extended Warranty | Superskoda Bits & Bling
So is there a problem with the XDS/XDL on your car, or do you just feel it doesn't have much effect? AFAIK it's not designed to rein in big wheelspin (the T/C is for that, and the last thing you'd want to be doing is putting all that load on the brakes), but rather marginally diverting torque to the outside wheel by increasing the resistance to the unloaded wheel while accelerating with a fair amount of lock on.
Anyone try the TSC yet? It's been lousy weather in Adelaide and I've not yet had time to code my car and go for a hills run.
