I don't have 100% confirmation from VW Aus, but I believe the 502/505-spec 5W-40 oils are ok in the petrol engines.
Liqui Moly Toptec 4100 is 502/505-approved, as is Penrite HPR-5.
You can run 502/505 in a petrol engine yes Using a non approved oil of the correct spec may not void your warranty but may upset VW if you have an engine claim.
MY07 Red GTI 3 Door
Correct. 504/507 is meant to be good for 30K drain intervals, although I wouldn't tempt fate...
I'd rather use 502/505 and change every 15k than 504/507 every 30k.
I use 502/505 in 5w40 due to oil consumption issues using 5W30 in my MkV GTI.
Sent from my SM-G930F using Tapatalk
MY07 Red GTI 3 Door
In a petrol engine, that's fine.
But not in a diesel, where 504/507 is a must.
The problem in the USA with 504 is the low additive levels don't work well with the alcohol and sulphur in our gas. Dealers use 502 5w-40 and 10k intervals.
I don't trust any oil past 10k, the downside is too great.
Direct Injection can ruin most any oil....
Supercheap have Nulon Full Synthetic European VW 504/507 10 litre for $61, normally $122, until 15th October 2017.
Nulon Full Synthetic EUROPEAN Engine Oil - Supercheap Auto
