Page 19 of 22 FirstFirst ... 91718192021 ... LastLast
Results 181 to 190 of 218
Thread: Why you need to use 504/507 oils in FSI/TSI/TDI engines!
  1. #181
    Pacific Paradise QLD
    Penrite Enviro + 5w30 when on special at Autobarn is what I use VW filter
  2. #182
    Dec 2008
    Sydney/Canberra
    Quote Originally Posted by Throbbinhood View Post
    A little confused after almost 20 pages haha!
    B6 3C 2007 Passat Wagon 2.0TDI with DSG. 125,000kms.
    15k service intervals preferred. What engine oil (and filter) should I use? Any notably better than others? Any cheaper oils that are still good to use for these?
    Any 5W30, as long as it has the 504/507 approval on the label.
    The Shell version is usually around $65-$75 at Supercheap.
    As for the filter, Genuine VW, Hengst, Mahle, or Mann are the go. Don't use the Ryco or Wesfil filter for these. They are garbage.
  3. #183
    Legends, thanks guys.
  4. #184
    Apr 2010
    South Morang, Victoria
    Supercheap have 5L Castrol Edge 5w30 VW 504/507 spec for $63...any good, or better to spend more on something like the Liqui Moly?
    Castrol Edge Diesel DPF Engine Oil - 5W-30, 5 Litre - Supercheap Auto
    What are your thoughts on Sakura oil filters?
    For a 2009 Caravelle, 2.5 TDi 96kW.
  5. #185
    Quote Originally Posted by blaast View Post
    That is the good approved stuff and is as good as you need and meets the same specs as the others you mention
    Dont know about the filters
  6. #186
    Dec 2008
    Sydney/Canberra
    The oil is fine, but the filter is garbage. The O-ring is not thick enough and will cause the cap on the oil filter housing to leak. Plus, more often than not, the filter will probably collapse over time.
    Try and avoid brands like Ryco, Wesfil and Sakura on these. They're crap.
    A genuine filter for these - 071115562C is only $25. Alternatively, OEM brands like Hengst, Mahle, and MANN are decent too, and are a little cheaper.
  7. #187
    Jul 2011
    Aust
    I was using the 5w-30 Castrol 507 dealer approved oil (change twice a year for 3.5 years) and found that it would drink the oil. Around 1L per 2500-3000km. I also found my Renault ClioSport would drink Castrol oil whereas when I ran Elf it didn't consume any (10,000km changes)
    I recently (one change 5,600km) switched to Liqui Moly Top Tech 4200 and it has used only100mL in 5,000km
    Wonder if this has been the experience for others?
  8. #188
    Adelaide hills, SA
    Quote Originally Posted by minke View Post
    It varies from model to model.
    I also have great experiences with Elf/Total oils.
  9. #189
    Apr 2010
    Thanks for that advice.
    I bought a couple of Sakura filters a year ago and used one at the time and have just changed the oil using another.
    When I took the filter out I noticed that the 'fins' were twisted, but was told by someone that this is normal due to the pressure exerted by the oil.
    I was skeptical about this, and it seems l should have been moreso!
  10. #190
    Oct 2009
    Mitchelton, Qld
    Quote Originally Posted by Umai Naa!! View Post
    TDI is 4200 only.
    Petrol engines can run 4100, or 4200.
    4100 Liquid Moly appears to only be in 5W-40? This is fine for Skoda Octavia RS 2012 TSI Manual and won't void warranty even though it's not VW 504/507?
    TOP TEC 4100 | 5W-40 – LIQUI-MOLY Australia
