Page 8 of 13 FirstFirst ... 678910 ... LastLast
Results 71 to 80 of 124
Thread: Whistle sound from GTI engine... Water Pump Failures
  1. #71
    Sep 2009
    seaforth, nsw
    i doubt it, no whistle since i got my water pump replaced, and that was 2 weeks ago and ive driven about 700km
    2011 cw golf gti 3dr man-tint-rear cargo mat-weathershields-bluetooth-mdi-19" oz racing ultra leggera-mcgard lockbolts-boston acoustic pro60se-jl audio xd700/5-jl audio bass tube bb-w060p- titanium exhaust tips-eibach custom pro-kit-OPS-OSIR cf mirror covers and cf front lip-dieselgeek short shifter
  2. #72
    Mar 2011
    Wollongong
    Yep had pump replaced and no whistling since, see how we go.
    They also polished the front windscreen for the speckles in the sunlight and it seems a bit better now.
    2011 5DR GOLF GTI DSG 6 CANDY WHITE - LEATHER, SUNROOF, 18" DETROITS, MDI, BT
  3. #73
    Mar 2011
    Wollongong
    Well today I noticed whistle again!!!!!!!!
    I released pressure at reservoir and it stopped. Will monitor and see if it persists. If so will be getting that done AGAIN along with the rattle clip fix.
    Has anyone else had their whistle fixed and then it return???
  4. #74
    Nov 2008
    Bankstown
    Dear JPanDAX,
    Interesting you should mention relieving the reservoir cap. I did not have a problem until I topped up the coolant. That is when I noticed the whistle. You can read my previous post, I have not had the water pump replaced and the whistle has not returned.
    I wonder if removing the cap has some temporary reaction in regard to the whistle. Strange I agree, but we will have to wait and see.
    I still believe that there is more to this than just swapping a current w/pump for another current w/pump, I mean surely they are not like capacitors with massive tolerances.
    Regards John
  5. #75
    May 2011
    NSW
    I started noticing the same whistle a few days ago (my GTi is only 2 weeks old, now with 500km). After reading some of the above entries, I released the pressure in the reservoir and it stopped immediately.
    JPanDAX, how soon did the whistle return after you released the pressure?
    MY12 Mk6 5 Door GTI | Carbon Steel | Manual | Leather | Adaptive Chassis Control | Bluetooth | MDI | Tint |
  6. #76
    Sep 2009
    seaforth, nsw
    take it to the dealer to get warranty on it
  7. #77
    Aug 2011
    Sandy Bay, tasmania
    whistle / squeal on 118
    I've read about the squeal problems on the 118. Does this only happen on the DSG or does it also occur in the manuals? I've noticed a soft whistle/squeal sound on a manual I'm considering. Only happens in 1st and 2nd gears below 3000rpm and you can't hear it if the radio is on. Not sure if this could be the water pump issue or is just the normal sound of the turbo.
  8. #78
    Feb 2009
    Sydney, Australia
    Does it stay on if you turn off the aircon?
    Some members have confused the recirculation fan sound with a engine bay noise.
  9. #79
    Aug 2011
    Sandy Bay, tasmania
    air con was off but fan was on low setting.
  10. #80
    Oct 2010
    Melbourne, VIC
    Quote Originally Posted by dood View Post
    Since you mention 118's, are you sure this isn't the water pump/supercharger clutch issue?
