Grip will be improved on smooth surfaces.
Fuel economy and ride will almost certainly suffer and tyre replacement costs will go through the roof.
If the 17" wheel/tyre combination is much heavier than the OE (almost guaranteed unless you are VERY careful with your wheel selection), then acceleration, braking and turning response will be slower due to the increase rotational inertia and grip on bumpy surfaces may be reduced plus ride will further degrade.
Resident grumpy old fart
