You wouldn't have got caster & camber in mm. It's only ever measured in degrees.
0.5mm toe-in front & 1.75mm toe-in rear is within spec (it's about 1mm +-1mm total toe).
What are the rest of your measurements?
Specs are in here. But I wouldn't run any more than -1.25 degrees camber on the rear even though it says you can go to -1.85degrees as you will get sawtoothing.
I agree though, the "come back every xxx kilometres for a free check" are fairly useless. I know when i was doing them, I'd be getting the free customers on & off the rack as quick as possible at they weren't helping me make bonus.
OTOH, what did you expect if everything was in specification & there were no issues?
If you are in Woodford NSW I'd suggest you go to Sydney Suspension (used to be Wholesale Suspension) in Penrith. Tell them how you want the car to feel and they can set it up accordingly. Most people don't like them set up "lively".
