Results 1 to 9 of 9
Thread: What kind of a supercharger does a TSI engine have?
    Mar 2015
    What I mean is that the TSI supercharger isn't like a "done up" muscle car with a supercharger that wines. I just don't understand what it does in this engine. Is there an extra belt?
    As you can probably tell, I'm not very knowledgeable when it comes to car engines. Any information regarding this would be great!
    Thanks!
    Jan 2013
    Brisbane, QLD.
    Quote Originally Posted by Kiark View Post
    Thanks!
    There is a belt connected to the coolant pump for the supercharger, it's a separate small belt. There is a changeover flap that regulates when the supercharger hands power over to the turbo 1500-2500rpm range I believe. The supercharger is there for low end power while the turbo spools, then the turbo takes over, this is to give the vehicle a more 'constant power flow'. It's not really made for performance so to speak, more so fuel economy, 'less turbo lag' etc.
    Apr 2015
    Woodgate Beach QLD
    Hi Guys
    If you are looking for great throttle response before boost and beyond look no further than the Throttle control module supplied by SKY Performance.I have had mine installed on my TT for a fortnight and I still can't believe the instant responsiveness that it has given.It feels like you have boost from the second you accelerate.10 minute install and has also improved mileage 7.3 lt/100k @ av 103kph Audi mk2 tt 2 lt bwa tfsi
    apsolutely a mod not to go past.
    Talk to Jose at Sky Performance and check it out,Also great service and quick delivery direct from Germany.
    Mar 2015
    Quote Originally Posted by The One View Post
    You're a legend! Thanks heaps!
    Trinidad and Tobago
    If you modulate your throttle pedal appropriately you can hear the supercharger whine. The supercharger operates from 1500 rpm to 3500 rpm. It's best heard in manual mode starting from gear 1 and max acceleration. Above 3500 rpm the clutch in the coolant pump is disengaged and you only hear the turbo afterwards.
    Trinidad and Tobago
    Have a look here for more info on the make of supercharger used in the 1.4TSI
    View topic - supercharger pulley for 1.4 TSI • SCIROCCO FORUMS, friendly community, info, news & advice.
    Mar 2015
    Thanks, Rawcpoppa. Will definitely check that out!
  8. Supercharger turns off at 3K Rpm... It's only a slight dip in power when it does but it is noticeable on a dyno (power curve flattened out and the raised a lot)
  9. Quote Originally Posted by Kiark View Post
    Thanks!
    It's very much a fuel economy and Turbo Anti Lag measure. Because our 1.4's have a K03, it will spool a bit latter than a 2.0L engine can spool it, they chuck a super on ours to negate that
