True, but in the GTI if you're tyres are fine and you're on a road which has even grip between your left and right wheels, it doesn't exhibit torque steer, you'll usually just lose grip in both wheels at a similar time.
The guy in the review of the 300KW GTI said it did have some, but bugger all. In my MKV Stage II GTI with 205KW, I couldn't get any at all in the dry, and only slightly in the wet if I purposely turned off the ECU and then irresponsibly put my foot to the floor from a stand still*. Then in that situation the car would usually start moving off in the direction of the camber of the road, rather than always to the left or right. I can't imagine VW have changed the MK6 for the worse in this respect.
*Note that with the original Bridgestone tyres the car would just bounce and shudder, but that was fixed by getting a different brand of tyre![]()
