All of these cars will be fun to drive on the track... whether they one is more fun to drive on a daily basis is the question.
IMO -
1. If you are not going to be taking the car to the track
2. Will be using it as a daily drive
3. Want to have smile on your face each time you drive it and not loose your license at the same time.
A car that is smaller, lighter, (with decent power to weight ratio) is the answer. It isn't about all out speed.Take a drive in a J-class go-kart (which travel at about 120km/hr) and you will know what I mean.
The Golfs are no longer small, light weight cars. You will have to drive them at license losing speeds to extract the thrill of driving from them. They are too composed for the speed limits of our city roads.
To add to the above, it's good having something with a decent amount of useable torque for the streets (like the R32's and some diesels), i'm sure the S3/Golf R would be fun on the track where you can really wind it out, but by the time you wait for the full power you're easily going over the speed limit.
Having said that, your power to weight would be good i thought Triode, if you've retuned the Pirelli, just different power delivery.
The R32 is a bit heavy but gives you a good planted feel and i've got lightweight wheels to compensate but still keen to lose the spare for a repair kit. Looking at other cheap runarounds and there are a few good fun cars that aren't super powerful like the 206 GTI 180 and Clio 182 Cup & MX-5's but are all quite small. when i owned the DC2R Type R i found that to be an ideal weight and heaps of fun.
I race karts in Clubman Light with S-motors and I can assure you J-class do not go 120km/hr, unless of course you've flashed the ECU
Ours run at a top of 110km/hr and on a 900m track we are 5-6sec a lap faster than the J-motors. Maybe sitting so close to the ground has distorted your speed perception!
I had a Clio Sport before the R32. Was a really fun carJust a shame it decided to randomly start shedding bits and pieces.........can't say the build quality was overwhelmingly good.
I've started looking at second hand R32's again..................
I'd wait for the Golf R before making any decisions. It's lighter than the R32, has more power AND torque, and is faster in acceleration. You could assume since it's lighter and has a new haldex unit etc, that's also probably better around corners.
The negative points in the reviews I've seen so far have only said that it is more refined than MKV Golf's and so seems a bit 'boring'. But then, many reviews of the R32 said the same thing.
UNLIKE the R32, if you DO find the car a bit boring, a $1695 ECU update will give you substantially more power and torque and, as others have commented even here in relation to the S3 after ECU update, will make it a much more pleasurable drive, even just around town.
If it was a bit too refined i'd get an exhaust as well which would probably fix that issue.
