Results 1 to 6 of 6
Thread: Warning lights on after battery change!!
    Jan 2012
    Need help again please. Just changed my battery and now when I switch on the car I have an ESP fault on the MFD and the steering wheel, ESP and tyre pressure warning lights are on.
    What have I done????
    Using my Maxscan no faults are found.
    2015 Golf R. Lapiz Blue.
    Adelaide hills, SA
    Most of them should clear when you drive off. You may need to reset you TPMS.
    Jan 2012
    I've not driven yet so I'll report back. Thanks.
    Mar 2013
    Brisvagas
    Esp and tyre pressure monitor relies on the abs sensors. After a battery disconnect you may have to reset TPM and drive a couple of hundred meters to let the system calibrate.
    Dec 2010
    Perth
    I changed my battery about 2 weeks ago and the guy who installed it said just drive forward about 20m and then reverse back the 20m. I did that and the fault lights cleared
    MY11 5 dr Golf GTI | White | 6Sp Man | MDI
    Formally known as GTI_WRAITH
    Jan 2012
    Thanks to everyone. I should of just drove it after I had fitted, reversed out of the drive way went about 5 metres forward and all the lights went out.
    Thanks again.
