Yeah I guess. 20 years building rally engines, what would I know?
Aircraft engines are always warmed up on the ground, a miss on take off can kill you, a pilot who doesn't warm engines up before take off has a death wish, in addition Aircraft engines have strict hour limits after which they MUST be stripped down and rebuilt. The piston engines used in aircraft are, as a general rule, also much less advanced then modern car engines, a mate flies a reasonably modern plane with a 4 cyl 5L pushrod/OHV Lycoming engine that makes a huge 160hp - hardly what you'd call pushing the envelope of performance. If anything aircraft engines have less in common with a Golf engine then the F1 example used earlier. The example I gave earlier with a big end is exactly the point. When you put a liquid under pressure between two surfaces close together it spreads out and holds those two surfaces apart, if you hold those surfaces a long way apart and squirt a liquid between them it simply flows out along the route of least resistance, by doing that it can't hold the surfaces apart effectivley.
That IS basic physics (surface tension of liquids + thermal expansion of metals)
I won't argue any further as everyone applies their own knowledge to any problem presented and make their own descisions on what to accept as correct, but it's always a mistake to presume the knowledge of others.
