Page 3 of 9 FirstFirst 12345 ... LastLast
Results 21 to 30 of 87
Thread: VW Golf VI: reliability issues ? real or not ?
  1. #21
    Feb 2010
    The Golf Withdrawn From Production!
    OK, valid point, but does anyone really believe the 6th generation Golf will die out?
    Anyway, it was a good excuse to put up the "worship" smilie!
    p.s. some other things to consider when buying a car, besides Reliability Rating:
    • Safety aspects
    • Fuel economy concerns
    • Considering Environmental Impact
    • Depreciation factor
    • Insurance costs
    • Make and model
    • Manual or automatic?
    • Gas or diesel?
    • 4 cylinder or V6?
    • etc.. (source http://www.samarins.com/choose/index.html)
    VW
  2. #22
    Jul 2009
    All I know is - 8000km on ours now and nothing to complain about. Yes, it has the occasional chirp from the supercharger clutch when you shift gears (and it's not a constant thing either) but this is only audible if you have the radio on mute. Other than this - perfect. I've looked after it and it's looked after me. Just completed the 7,500km oil change for good measure.
  3. #23
    Jun 2007
    Not sure Consumer Reports is the best source. They make predictions on how reliable they 'think' an upcoming model will be and apparently show some unfair bias according to Vortex members.
    Also are consumers the best judges of their cars problems?
    I find Warranty Direct quite good because they log Warranty claims ie actual repairs done. Shows the Mk V Golf to be about twice as reliable as the average car.
    http://www.reliabilityindex.co.uk/se...28339010848601
  4. #24
    Feb 2010
    Quote Originally Posted by PassatB6 View Post
    ...shows the Mk V Golf to be about twice as reliable as the average car.
    Interesting. Thanks for the comparison.
    VW
  5. #25
    Canberra
    If you want high reliability go older tech. ie most Japanese brands and Skoda which gets most technology after its been sorted in VWs.
    Not so much as some think. Skodas got the new EA888 family of engines before VW (eg the 1.8 in Octavias), and sometimes they get new platforms before VW. A lot depends on where the different models are in the replacement/upgrade cycle. Skodas got the new CR diesels at the same time as VW.
    You are correct about Skodas usually rating higher in reliability surveys than VWs, and based on my sample survey (one of each) I concur .
    Many of the problems VW have are in the minor parts from outside suppliers (eg I've had 3 different locking units replaced on my VW).
  6. #26
    Jan 2008
    Quote Originally Posted by gregozedobe View Post
    I assume you mean door locks? If so it's the same part on the Skoda's.
  7. #27
    Closet Diesel Owners Club President.
    Supercharging a Turbo is no different to having just a turbo or just a supercharger....the engine has boost. Whether you have 1, 2, quad turbo it is the boost pressure that puts stress on the engine and the 118TSI's and GT TSI motors don't go above 18psi under load and mostly sit between 10-15psi which is hardly anything for an IRON BLOCK!
    EVO 9's have an Iron block motor and often run huge turbo's on stock internals as do RB26 godzilla motors. I bet the iron 1.4 blocks could handle 25psi with the only part likely to get damaged being a head gasket due to headbolts lifting. Stress less! Also, on the supercharger front, my dads last car had a sealed supercharger unit like ours and it worked flawlessly for 10 years, still going strong when he sold the car.
    In summary: The block and the supercharger will outlive your ownership. The turbo will last probably 150,000 before the seals go.
    *Disclaimer - Don't rely on me, seek your own professional advice. Audi R8 E-tron. 230kw 4500nm! (not a typo).
    Economy at 100kph =5.5L
  8. #28
    Feb 2009
    love my car. perfectly reliable, not a single fault (1 or 2 minor fixes/adjustments)
    Had a ford focus before it, and that was a nightmare..I can't imagine how stuffed it would be if I actually didn't look after it!!
    Don't care if toyota has better reliability stats, its like driving a microwave owen to work LOL. I've driven a number of far more expensive car's and would not swap for my golf, and have impressed 2 many people with the Hi-Tech of this car.. If i won the lotto tomorrow i would not swap my car.. not because you cannot buy a better car, but because I am so pleased with how well the car has exceeded my expectations in every way and how happy i feel driving it.
    |Golf Mk VI 118TSI|Manual|Pearl Black|Sports Pack|Sunroof|F & R Parking Sensors|Park Assist|RVC|Alarm|RNS-510|VW Premium Bluetooth|MDI| http://www.hoodiaslimming.com.au - 100% Pure, 100% Organic
  9. #29
    Jan 2010
    State of Denial
    Remember the leaked australian reliability survey data that came out a couple of years ago? From memory it was based on the number of faults reported in the first 5 months - the differences between the middle ranked and best cars wasn't much more than 10%. Of course the surveys didn't comment on the nature of the faults. As an owner a rattle in a door trim is annoying but can be put off until the next service whereas a hole in the piston can't.
    Longer term warranty data is more relevant becasue its the sort of thing that will end up costing you real money.
  10. #30
    Feb 2010
    Aren't these an alloy block motor ?
