Originally Posted by
wai
If you are going to be driving a fair distance immediately, then it is OK to try and add more after the first shut off. If you are just going to try and get a few litres more, then you can have issues with excess fuel spilling. You should remember that the fuel can be quite a few degrees cooler in the underground bulk fuel tanks. Not only are the tanks covered in soil that insulates them, underground tanks are also double skinned with the space under slight vacuum. This is used as an indicator that the main tank has failed if the vacuum in the space disappears. On a hot summers day, you can get a significant expansion of the fuel.
