Page 3 of 12 FirstFirst 12345 ... LastLast
Results 21 to 30 of 118
Thread: VCDS / VAG-COM settings to make GTI needles dance upon ignition
  1. #21
    Feb 2008
    Richmond, VIC
    Quote Originally Posted by Olaf the Golaf View Post
    I want to see if this can be done on my 118TSi (not holding out much hope, but you never know)
    so the - 17 instruments >> 10 adaption >> staging - instructions, I'm assuming they're menu titles in the car dash? i realise that sounds like a totally noob question, but just wanted to confirm it.
    No, u need a vag-com cable
    Ross-Tech: VAG-COM
    and a laptop to change some hidden configuration settings.
    currrently... MY10 GTI | DSG | Candy White | Sunroof | 18's | BT | MDI
    previously... MY08 GT TDI | DSG | Reflex Silver | Sunroof
  2. #22
    Feb 2008
    Richmond, VIC
    OK, I got it, double checked everything, turns out i had to do the following to get it to work.
    Change the setting.
    Close Vag-Com software
    Unplug cable
    remove key from ignition
    lock car
    unlock car
    key in ignition
    turn on car.
    sweepy goodness.
    It looks like clusters 5K6 920 870 D and 5K6 920 970 H will activate. I have the latter in mine.
    this is handy too. http://forums.vwvortex.com/zerothread?id=4743553
  3. #23
    Mar 2010
    Quote Originally Posted by steve_tdi View Post
    Change the setting.
    Unplug cable
    lock car
    unlock car
    key in ignition
    turn on car.
    sweepy goodness.
    this is handy too. VWvortex Forums: VCDS MKVI / MK6 Platform, Handy Coding tweaks
    What are clusters 5K6 920 870 D and 5K6 920 970 H? My dealer said he can do it for me if I provide him with the coding/instructions.
    MkVI Golf GTI | Candy White | DSG | Leather | Bi-xenon | Sunroof | Dynaudio | Park Assist | MDI | Tint | FINALLY RECEIVED!!
  4. #24
    Feb 2008
    Richmond, VIC
    Instructions are in that post i linked to.
    Basically go to the Instruments Section (17) There you should see under Controller info VAG Number...
    Then Click on Adaptation and drop down to "Staging"
    Set Staging to "Active" and click Do It!
    Its a 2 minute job if u know where to look.
    Im happy to code it for you if your dealer cant along with a few other things that can be done.
  5. #25
    Feb 2008
    Ringwood North, VIC
    Hi all, does anyone know if this works for Current model passats? yes i know this is a golf forum, but I have just tried and it said the service not installed, my instruments are version F, (not sure what the number was) I have just also seen it on Passat CC's from the states.... I want mine to do it
    2010 MY10.5 R36 Wagon, Biscay Blue, RNS510, Dynaudio, Sunroof, towbar, Dynamic Chassis Control, No lazy back door
    2008 Audi Q7 4.2TDI, Radar Cruise, Lane Assist, Blind Spot Assist, Heated Seats Front & Rear, Alcantara Hood Lining, Wooden Gear knob, Nappa Leather, Plus all the usual V8TDI gear, like 760nm of Torque!
  6. #26
    Mar 2010
    Thanks for the info, I'm going in to see my dealer today and I'll be getting my GTI tmr! Hope everything goes well! =)
  7. #27
    Mar 2010
    Just went into the dealer, the guy from service said that the 10 Adpatation bit doesn't tell him the channel and he might not be able to find it...
  8. #28
    Feb 2008
    Richmond, VIC
    Yeah, their VAS System is different to VAG-COM, and i gues a bit more "locked-down" to only do the things that VW australia want them to do.
    I have a pretty good relationship with my service dept and they couldnt do any of the things i wanted...
  9. #29
    Mar 2010
    Do you think you can help me with it steve? I quite like the sweeping needles >.<
    ps: we've got the same colour for our GTIs =D
  10. #30
    Feb 2008
    Richmond, VIC
    Quote Originally Posted by MkVIGTI View Post
    Yeah mate, always happy to have a tinker.
    Quote Originally Posted by Caddyman View Post
    From what i have read up on, its Mk VI GT's built after week 45 2009 that can have it activated. If u tried it and it doesnt work then chances are its probably not supported.
