Page 7 of 12 FirstFirst ... 56789 ... LastLast
Results 61 to 70 of 118
Thread: VCDS / VAG-COM settings to make GTI needles dance upon ignition
  1. #61
    May 2010
    WA
    Agreed. I doubt 3 is sufficient for the driver to be sure/confident that other drivers spot the indicators esp when they are busy looking elsewhere.
    [MK6 GTI MY11 CW 3-door DSG Sunroof Detroits Dark Tint R LEDs APR Stage 1 (regrettably a few years late)]
  2. #62
    Jul 2010
    I think I found it here
    yeah, with 3 blinks, the last blinks ended when I'm halfway into the other lane... unless I change lane using an agility of a go-kart/F1 driver which is not something I want to do on daily basis in commuting traffic.
  3. #63
    Jul 2010
    just tried that setting on the link above, it works.... my needle now 'dance' - can't believe the instant surge of power felt... (was that 11kw?)
    lol
  4. #64
    Manly - Sydney
    Any luck on the 118 tsi's? I'll buy a VCDS just for that if it works lol.
    Stoney!
    6 Sp Manual 118 TSi
    Colour: United Grey
    Build Date: August 09 Delivery Date: 16th Oct 09
    ODO at last fill: 2555km
    Avg Fuel Cons at last fill: 8.6
  5. #65
    Nov 2009
    Quote Originally Posted by Highlander View Post
    Is it true that the dancing needles add about 11kw but have been disabled in Australia because of our tropical climate.
    If it does, I'm doing it to the Polo ASAP!
  6. #66
    Jul 2010
    Quote Originally Posted by rs73 View Post
    lol
    after a few days havin' this feature enabled just thinking if it occured to you guys' mind whether having the needle swap might prematurely worn off the spring or whatever mechanism that makes the needle moves?
    same thing with fog light as cornering lamp, I find on the GTI the fog light either isn't bright enough or not aimed to the side enough to be a perfect cornering lamp... and prematurely burnt fog bulbs also comes into mind... especially if you do lots of night driving which involves a lot of low speed corners?
    by the way the 4 indicator flash works a lot better... perfect amount of time to execute the manouvre... i won't bother changing it to 5
  7. #67
    Feb 2009
    Sydney, Australia
    Considering the needles move constantly as you're driving the car anyway, I hardly see how it moving for another 3 seconds before you drive off will shorten their life
    As for the fog lights, using them more often is obviously going to reduce their life.
  8. #68
    Nov 2009
    That extra flash is going to reduce the life of the indicators!!!!
  9. #69
    Feb 2009
    Sydney, Australia
    Quote Originally Posted by dave- View Post
    Nah... you'll just have to replace your indicator fluid more often!
  10. #70
    Nov 2009
    QLD
    hey guys, just got my Micro-Can cable so if anyone in the gold coast area wants staging, give me a shout. Also, does the acceleration measurements not work with a micro-can? cant seem to find the button as it is displayed on the ross-tech manual
