Are the buttons near the sunglasses holder only present if you have premium bluetooth or something? I don't have the buttons at all on my MY11.5 GTI
MY12 Golf R | 5 Dr | Candy White | DSG | 19"Black Talladegas | ACC | RNS510 SATNAV | Sunroof | RVC | BT | MDI
Ordered - 28/02/12 | Collected - 14/03/12
BMW Z4 (2019)
Audi TT quattro (2015), s-line in Nano Grey - sold
Probably, as they are all "call" type buttons. VW Assist, VW Care and the * button. The only one that works I am told is the * button, but someone says he has programmed another button which is handy, probably through the MFD setup menus.
If you don't have Bluetooth, you can't call anyone.
Thanks. I've got Bluetooth but the crappy dealer fit one that pretty much does nothing except answer the phone, no phone book etc
BMW Z4 (2019)
Your missing out. The factory Bluetooth is sensational. Does and has everything. Can control through the steering wheel buttons on the MFD as well, no need to use the touch screen RNS. Get it for your next car. I think that Bluetooth function in this day and age is a must. Was for me.
You need to program the numbers using VCDS and a VAG-COM cable The numbers are pre-programmed to dial Europe numbers!
Anyway if you have access to VCDS and cable you can prorgam as follows:
Under the Telephone module (77 from memory) goto "Adaption" this displays a long list of options. At the bottom of the drop down list the are four phone number fields. There are two for each button, the "i" button and the spanner button.
Jimmy from the VWWatercooled forum provided the information below that worked for me:
The Service/Breakdown coding requires 7 bytes which are entered as their raw numeric values. So for VW roadside I entered 18 00 63 71 81 00 00 (note padding with 0's for the last two bytes). The Information number requires 8 bytes, again pad with 0's for the extra bytes.
Program the buttons for any number you like. I found that all four numbers need to be entered for it to work.
Once programmed, you press and hold the button for 2 seconds and the it dials the number. The MFD displays the hold for 2 second message, then it displays either INFO CALL or SERVICE CALL (or something to that effect)
Good luck. BTW using the VCDS is up to you, there is always risk associated with programming your car via VCDS. If you choose to use the information above, you do so at your own risk.
Cheers Brett.
Golf Mk6 103TDi (Dec 2011)
BMW Z4 (2019)
