Hey Guys,
I was driving along earlier tonight and a warning light came on randomly. I don't know what it is and am going to call the dealer tomorow to ahve it checked out but i was wondering if anyone could give me some info prior to going to going to the dealer tomorow.
It's the yellow light that is pictured as follows: It has an exclamation mark surrounded by a yellow circle that has an opening at the top. It is on the speedo not the rev counter side.
If anyone happens to know what i'm going on about please do help.
I'm going to go find the manual and try figure it out.
"I just want to make it that little bit better, and little bit more unique."
Agreed, check the manual![]()
Russ
2005 Subaru Outback 3.0 R Premium
GTI MKVI Candy White | 5 door | DSG | ACC | 18" Detroits | Leather | Electric Seat | Sunroof | RNS510 | Dynaudio | Park Assist | RVC | MDI
website: www.my-gti.com
Hit up the manual mate - should have most if not all the answers![]()
2019 BMW M3 CS
It's your tire pressure indicator, it thinks one tire is low or there may be a fault in your system.
Check all tires as soon as possible and re-set your system (hold down the button with the ignition on until the indicator goes of and you hear a ding)
The system works of your ABS and it mat have been that one side of the car was on rough road surface.
I was trying to give my passenger a thrill by running along the white line rumble strips, that caused the thing to go off (the alarm, not her). I just checked my pressures and re-set the system and haven't had any issues.
O.K so i checked the tyres today and they were all at around 40psi. Is that the right pressure?
I put them up to 42 just for the sake of it, but yeh.
Now i went through the manual and it says the button to reset them is on the set where the esp button is located. Only thing is, i only have the esp button there....no other ones....where do i find the button?
Thanks again.
