Page 1 of 7 123 ... LastLast
Results 1 to 10 of 68
Thread: Tyre Pressure Monitoring System
    Dec 2009
    Brighton, Victoria
    Warning light just came up!!
    Hey Guys,
    I was driving along earlier tonight and a warning light came on randomly. I don't know what it is and am going to call the dealer tomorow to ahve it checked out but i was wondering if anyone could give me some info prior to going to going to the dealer tomorow.
    It's the yellow light that is pictured as follows: It has an exclamation mark surrounded by a yellow circle that has an opening at the top. It is on the speedo not the rev counter side.
    If anyone happens to know what i'm going on about please do help.
    I'm going to go find the manual and try figure it out.
    "I just want to make it that little bit better, and little bit more unique."
    Nov 2007
    Quote Originally Posted by GTI2708 View Post
    I would've thought that would be step 1... Your manual will probably know more about that icon than anyone on here.
    Jun 2008
    South Coast N.S.W.
    Agreed, check the manual
    Russ
    2005 Subaru Outback 3.0 R Premium
    Sep 2009
    Perth, WA
    Hey Guys,
    Find the manual - it will tell you. Pretty sure it's the tyre pressure indicator. Go to a service station, check the pressure in each tyre, then press the reset button in the glove box.
    I had to do it the other day even though the pressures were fine.
    GTI MKVI Candy White | 5 door | DSG | ACC | 18" Detroits | Leather | Electric Seat | Sunroof | RNS510 | Dynaudio | Park Assist | RVC | MDI
    Jan 2008
    The manual is in your glovebox, shouldn't be too hard to find. You can even pull it out when the problem occurs and see if you can continue driving safely or not!
    BTW your warranty doesn't cover you if you ignore warning lights and keep driving.
    Dec 2009
    Hit up the manual mate - should have most if not all the answers
    2019 BMW M3 CS
    Sep 2009
    Melbourne - Vic
    Talking
    Hey Guys,
    It's your tire pressure indicator, it thinks one tire is low or there may be a fault in your system.
    Check all tires as soon as possible and re-set your system (hold down the button with the ignition on until the indicator goes of and you hear a ding)
    The system works of your ABS and it mat have been that one side of the car was on rough road surface.
    I was trying to give my passenger a thrill by running along the white line rumble strips, that caused the thing to go off (the alarm, not her). I just checked my pressures and re-set the system and haven't had any issues.
    Dec 2009
    Brighton, Victoria
    Quote Originally Posted by jimmyjames View Post
    Thanks for that mate. I figured that out from the manual earier but thx anyway.
    thanks to everyone for the help.
    Dec 2009
    Brighton, Victoria
    O.K so i checked the tyres today and they were all at around 40psi. Is that the right pressure?
    I put them up to 42 just for the sake of it, but yeh.
    Now i went through the manual and it says the button to reset them is on the set where the esp button is located. Only thing is, i only have the esp button there....no other ones....where do i find the button?
    Thanks again.
    Sep 2009
    Thanks again.
    The TPMS reset button is in the glovebox.
    2010 Mk6 GTI - Candy White, Park Assist + RVC, Dynaudio, MDI, R LED Tail lights
