Page 1 of 5 123 ... LastLast
Results 1 to 10 of 50
Thread: Tyre pressure
    Aug 2009
    Oyster Bay, NSW
    Tyre pressure
    I have the sports pack with 17" Bridgestone Potenzas. Car came with 51psi which is the max recommended on the tyre. Fuel cap suggests 230 2,3(33psi?). Do I assume is for 16" standard wheels or does it apply to the 17" as well? If not then what should be the pressure?
    Thanks!
    __________________
    Ex - MkVI Golf 118TSI Lemon owner!
    Sep 2009
    erm... you might have read wrong... 50PSI is something you would put into a bicycle tyre, and not a car tyre. ~33PSi sounds just about right for 17" with people filling it to 30PSI for a balance between comfort and grip.
    Jetta MK6 147TSI DSG Reflex Silver
    Pondering: too many to list...
    Aug 2009
    Melbourne, Vic
    Quote Originally Posted by Nicho View Post
    ...Do I assume is for 16" standard wheels or does it apply to the 17" as well? If not then what should be the pressure?
    Was discussed here at Tyre Press on Golf 6 thread. The way I read that label VW recommends same press for all three tyre sizes. Varies only with load.
    Dec 2008
    Sydney/Canberra
    Run them at 38, and enjoy the fact that you'll get decent life out of them
    Aug 2009
    Oyster Bay, NSW
    Thanks for the link logger.
    Checked the pressure again and it was at 50!! I have not looked that the tyres since taking delivery. Pretty average to have them delivered like that.....
    I have just dropped to 38 and will see how it feels.....excuse my ignorance on the subject Umai Naa but why 38 vs 33???
    __________________
    Sep 2009
    not sure why the exact figure of 38psi, but basically, with more pressure, you have less of the tyre in contact with the road, as compared to a tyre with less pressure. as long as the tyres are rated to take that pressure, then there's no harm there, though your ride would be pretty harsh.
    p.s. not even going to ask why they delivered your car with 50PSI in the tyres
    Dec 2008
    Sydney/Canberra
    They seem to last longer in the high 30's. Run them too low, and they chop the egdes out.
    50 is waaay too high. They don't even roll off the boat with that much in them!
    Aug 2009
    Melbourne, Vic
    Quote Originally Posted by Umai Naa!! View Post
    ...They don't even roll off the boat with that much in them!
    Unless someone/thing forgot to let them down after seating the beads. But unlikely for all four tyres I guess. In any case pre-delivery should have pickedthis up.
    Did you check your tire pressure in the day? (heat?) air expands in heat so it would give a higher reading than normal
    MKV GTI Pirelli
    Aug 2009
    Melbourne, Vic
    At around 1 psi per 10 degrees it would have to be as hot as hadies to make that big of a difference though.
    BTW I just stumbled on this in the erWin VW Maintenance manual...
    "The tyre pressure table is valid for standard tyres and for all tyre sizes fitted at the factory.
    The pressures in the table apply to cold tyres. Do not reduce increased pressures of warm tyres"
