Yeah, the manual isn't the clearest of things.
I just wanted to clarify though some of the wording in your post in relation to the "two stages of pedal travel before "full throttle" is reached."
Effectively there isn't two stages. Only 1. The 2nd stage does not apply any more throttle. It only engages the kick down.
Thus, if you push your foot down until you get resistance, then you have 100% throttle or "Wide Open Throttle" as some people might call it. Any further, and you get kick down - which may in fact kick down 2 or 3 gears depending on the situation. And yes, it can go well into the redline. You should really be changing gear up yourself when you're in M anyway...
