Page 1 of 3 123 LastLast
Results 1 to 10 of 28
Thread: Two stage accelerator?
    Feb 2007
    bright town VIC
    Earlier this week I pulled out into traffic and had to get a move on a bit more than I thought - I floored the accelerator and noticed there is an extra bit of give at the end of the travel...also noticed it didn't change up until over 7k RPM.
    Is this a feature?
    Dec 2006
    Kilsyth, VIC
    Our van does the same thing, it's like there is a "normal" travel portion of the pedal then a harder spring at the bottom. I asked this a while back and was told this was the kick down switch, which makes some sense, but I haven't confirmed.
    Feb 2009
    Gold Coast, QLD
    i had the same in my 05 TDi.
    MY18 MKII Tiguan 162TSI R-Line | Deep Black | DAP | Sunroof
    For Sale - MY11.5 MKVI 3DR Golf GTI | Pearl Black | Manual | Sunroof | Dark Tint | Dynaudio | MDI | Bluetooth | Bi-Xennons
    Mods | R Tails | P3 Gauge | LED Interior Conversion | Lakin Plates | VW Racing Springs | 19" RAYS 57Motorsport G07EX
    Feb 2009
    Sydney, Australia
    Quote Originally Posted by kevvie View Post
    Is this a feature?
    Yep, as documented in your owners manual, 100% throttle comes at a "resistance point", not "on the floor". If you push further than this, you will hit the kickdown switch. This will cause your car to downshift, even in "M mode" on the gearbox.
    The complaint that many people have about M mode not being completely manual is due to them not understanding this feature, or not being able to use their right foot correctly. Some people even put "stoppers" under the pedal so they can mash it as much as they want and the kickdown switch cannot be trigger.
    Feb 2007
    bright town VIC
    Thanks Corey. I read the manual again after your post and probably understand why some people would not pick that up, it's not particularly specific - when I read it the first time I just assumed that it would kick down if I floored it, like a normal automatic, and didn't realise there were two stages of pedal travel before "full throttle" is reached.
    Now that I know more I have played around a bit. What I also found interesting is that it will drop down a couple of gears in "manual mode" and go well into the red zone on the tacho before changing back up to the gear I was originally in - I saw at least 7000 RPM today vs a 6000 RPM red line.
    Feb 2009
    Sydney, Australia
    Yeah, the manual isn't the clearest of things.
    I just wanted to clarify though some of the wording in your post in relation to the "two stages of pedal travel before "full throttle" is reached."
    Effectively there isn't two stages. Only 1. The 2nd stage does not apply any more throttle. It only engages the kick down.
    Thus, if you push your foot down until you get resistance, then you have 100% throttle or "Wide Open Throttle" as some people might call it. Any further, and you get kick down - which may in fact kick down 2 or 3 gears depending on the situation. And yes, it can go well into the redline. You should really be changing gear up yourself when you're in M anyway...
    This features on nearly all auto cars produced in the last 25 years....
    MKV Golf 2.0 TDI DSG Sportline. Just nice.
    Feb 2009
    Sydney, Australia
    No it's not. You misunderstand what is being discussed.
    We're not talking about driving along in D, having 5% throttle and you pushing the pedal down to 50%, and the gearbox dropping a gear.
    We're talking about driving around in Manual, having the pedal already pushed down to 100% throttle, then pushing the pedal further down past the resistance point and hitting an ACTUAL BUTTON UNDERNEATH THE PEDAL. That button is what tells the car to "kickdown" even though you're in manual.
    May 2010
    Quote Originally Posted by Corey_R View Post
    Most autos I've driven have the same or similar button in the same place.
    GTI | Carbon | Man | 5 door | Leather | 18" Detroit | Bluetooth | MDI | Bi-Xenon
    Feb 2009
    Sydney, Australia
    We'll just have to agree to disagree.
    I've never driven and auto with one. I've driven Autos from Toyota, Holden, Ford, BMW, Mini, Suzuki, Hyundai, the list goes on. And even most dyno operators have never come across one, nor most car enthusiasts, since in almost every single "dyno thread" or "DSG" thread on these forums, someone complains about how the DSG won't stay in gear even in Manual, and someone has to then explain about this button underneath the accelerator pedal, and then people are surprised.
    So if "most autos" have actually had them (and not just your last car), this would then mean that "most people" here are ignorant, and "most dyno operators" are ignorant. And I'm sure that none of those are the case.
