Quote Originally Posted by prise View Post
... 80% torque at 1500 RPM is not hard on the engine as thermal loads are low and loads from cylinder pressures are modest compared to loads from reciprocating parts it would experience at higher RPM's...
But aren't the high rpm loads hard on bearings while the cylinder pressure loads are hard on pistons / bores and essentially independent of rpm?
