It all comes down to how you are driving. With all automatic transmissions, they go through a weekly cycle or however how often of re-programming themselves. Or possible from the moment you start driving.
The car learns your driving style through a 'fuzzy logic' (I know someone in this field of engineering who can confirm the existence of fuzzy logic) and adapts to your driving style. E.g. if you drive like a grandma the car will not inject as much fuel and will shift earlier, or if you drive harder the car will dump more fuel and downshift more eagerly, I found this evident and could be rectified in my primary car with taking the terminals off the battery to re-program it however do not do this on any VW as I have only verified this fix with Hondas to this date and I will not take any responsibility if you do it. However, it also depends on everything else such as flat ground, tyre pressure.
The 118TSI does sell on the merits of fuel efficiency and power as I've found with the 3 day old 118TSI it does have a 1 gear: 10kph shift point as I found myself cruising at 70kph in D7. Also upon coming off the line the DSG like any manual gearbox does take time to hook up the clutch as i find it dipping into the 900rpm range upon slight depression of the accelerator and the engine gets to the point where it wants to stall evidently in semi-auto and manual transmissions.
As for the rumbling I find it is like popular belief when driving any car, not feeding enough revs into the engine will cause it to stall and under load it will rumble as there is too much load. It may well be a combination of problems such as too high a gear and all, but this is what I think.
