Page 1 of 4 123 ... LastLast
Results 1 to 10 of 39
Thread: Twincharger 7DSG - Selects higher gear than it should. Thoughts?
    Aug 2009
    Melbourne, Vic
    When the Twincharger 7DSG is operated in "D", it will readily run at lower revs and a higher gear than most of us are used to. As anyone who has one will know it will climb a hill in 7th gear at around 60kmh and 1300rpm.
    There is a notion that with the Twincharger 7DSG operates at low revs in a high gear under load "..you are putting too much strain on it and that its bad for the engine."
    Quote Originally Posted by sillygogo View Post
    At the moment I found the car up gears too early..Upgear too early like car driving 55km/h in D7 around 1200rpm, I can hear the engine clonking, not sure if that the right term. Sound like if you starting a manual in second instead of first.
    Quote Originally Posted by dopey View Post
    That is the engine labouring, it's basically the engine crying for help because you're putting too much strain on it. It's bad for the engine in the long term.
    Thats what I think too, it reminds me of my early days of driving a manual, where putting into 5th instead of 3rd or 4th instead of 2rd.
    Not sure if other 7DSG drivers experiencing the same issue of having a higher gear than what it should be. At the moment I either drive it in S or if i see a hill coming, i would accelerate more, forcing the DSG to downgear(s)
    I disagree with this notion for the following reasons:
    1) you are applying anochronistic thinking to a a cutting edge piece of technology. We are not talking about a 20 year old holden with a manual transmission.
    2) I find it hard so believe that VW would design a car with a highly advanced powerplant and automatic transmission and then forget to configure it, so that in its most automatic idiot proof setting "D", it will allow the driver damage it when driving uphill in a liesurely manner .
    3)The ECU on the Twincharger and the 7DSG's Mechatronics unit will have all sorts of sensor imputs. I do not believe the designers would allow them to so readily operate in a regime where it could damage itself.
    4) The engine is said to develop maximum boost (not torque or power) at a meagre 1500rpm so surely it is designed to run under load in this regime. see Inside VWs twincharger
    5) My take on it is, the noise you are hearing is a characteristic of the Twincharger + 7DSG. It might be the supercharger or just the engine itself under load, but I reckon it is quite acceptable and I am happy to drive my car in this range until someone can give me a good reason not to.
    As always - happy to proven wrong. Can someone with specific engineering knowledge of these engines clarify this for us? Thanks...
    Jun 2009
    Logger:
    I am not really sure what is the noise i am hearing. I believe it is because the DSG is in a higher gear than it should be because, the engine vibrates, and "sounds like" in the wrong gear. That was how i found the sunvisor was lose. She is smooth and sweet once it is in to 5 or 6.
    I don't think it does any long term damages, however i do believe it is not running as efficent as it should be.
    GOLF V GTI DSG Silver : On loan to parent until wife thinks I am a responsible driver
    GOLF VI 118TSi DSG Silver Leaf
    GOLF VII 110TSi DSG White
    GOLF VII GTI pp : on negotiation
    Jul 2009
    It's all perception. I currently drive a Polo GTI. I have always "driven" the car the way I thought it should be driven until I saw a video on the VW German website on how to drive a manual VW for max fuel economy. Basically if you follow VW's recommendations, you will end up in 4th gear by the time you hit 40km/h. I tried it and ended up with a 2l/100km saving. Sure, I thought the engine sounds like it is about stall, but after a while, it started to sound normal. Like I said, what we "THINK" it should sound like, is often not the case at all.
    Sep 2009
    Bundaberg, Qld
    Yes the new VW 7Sp DSG does take "short shifting" to the extreme and while this may result in a fuel saving I do find myself constantly shifting to "Sport" mode for normal traffic light starts and some slow speed corners before shifting to normal "D" mode once it gets over about 30Kph. It just feels better. I think that the right config for me would be to just raise the rev range slightly for the 2 and 3 gear shifts.
    That said, "Sports" mode is too much for normal driving cruising.
    2009 Golf MkVI 118 TSI
    United Grey - 7sp DSG, Sports Pack, Sat Nav, Blutooth, Towbar, Park Assist
    2005 350Z Track Coupe
    Ultra Yellow - Lots of mods
    Best fuel efficiency in a petrol engine is moderate to low revs and throttle opened as much as possible (less pumping losses).
    Essentially this means you need to accelerate with lots of throttle but upshift early. This is exactly what the DSG seems to be doing. Keeping the maximum load on the engine.
    Sep 2008
    bne.qld.au
    Buy a manual. Problem solved.
    Aug 2009
    Melbourne, Vic
    Very Clever ...but seriously:
    There is no Problem to solve in the first place. People are trying to make it one and I would like to clear things up, so a myth does not perpetuate.
    So far no one has come up with a good reason not to let this powerplant and transmission operate within the manufacturers design envelope.
    Jul 2005
    gee i thought the 6speed dsg in my jetta short shifted way too early...
    its in 6th at 60kmh... roughly changes up a gear for each 10kmh increase.
    Does the job tho and find that i have learnt when to use the manual mode.
    1974 1300 Beetle, 1997 Golf GL, 2003 New Beetle Cabrio, 2014 Audi A4 quattro
    Nov 2007
    Perth
    a twin charged car doesn't seem to suffer for it.
    The only thing it chews is fuel if you're not on flat ground (as mentioned in the other tune thread).
    My gti (dsg 6) changes down much more readily than my tsi (dsg 6) did, but it doesn't have the supercharger supporting act
    the dsg mapping for a tsi, tdi and gti are going to match the capabilities of the engine.
    Jan 2007
    It's all about fuel efficiency, chasing the poofteenth of a litre per 100km savings that consumers seem to love. Remember VW detuned the TSI from the MkV GT (120 something kw?) back down to 118kw. No doubt they've programmed the shift points as efficiently as possible.
    Scirocco R | DSG | 19" Talladegas | Viper Green
    MkVI Golf 118TSI | 6spd Man | 17" Classixs | APR Stage I
    MkV Jetta 2.0 TFSI | DSG | 18" Charlestons | APR Stage II
