Results 21 to 30 of 39
Thread: Twincharger 7DSG - Selects higher gear than it should. Thoughts?
  1. #21
    Jan 2010
    State of Denial
    Quote Originally Posted by idaho View Post
    But aren't the high rpm loads hard on bearings while the cylinder pressure loads are hard on pistons / bores and essentially independent of rpm?
    As a general rule - yes. However diesel engines have proven that a properly designed bore, piston and ring arrangement can handle high gas pressures and still deliver long engine life so there is no reason to say why one type of wear would be worse than the other for our engines.
  2. #22
    Feb 2009
    Sydney, Australia
    I was thinking of replying as this was the first time I had seen the thread, but perhaps not. People are often berated for starting new threads without searching for and adding to existing threads, but it seems that searching and continuing on is also frowned upon. If a new group of posters wish to discuss this subject isn't it reasonable to continue this thread rather than start a new one?
    Quote Originally Posted by hooba View Post
    To me it's obvious, nobody likes a smartie who can master the #$@%@! search function on this forum.
    Sorry, maybe my post was a bit full on...
    My main point was, that VeedubTSI was not coming in to ask a question, but to "answer the thread" when the OP is already very knowledgable on the topic and created it to answer other peoples questions in the first place.
    Feel free to continue it though if there is new stuff to add...
  3. #23
    Sep 2010
    Quote Originally Posted by coreying View Post
    *sigh* I felt I was getting moderator bashed after your initial statement. At least I resurrected some topic of some significance as I've seen in the last few hours. I don't know where the lines blur between resurrecting a topic or starting a new one and getting it merged or bashed. All I know is I'm watching the posting dates more carefully next time.
    2010 Golf 118TSI (United Grey)
    2009 Golf GTI (Carbon Steel Grey)
  4. #24
    Feb 2009
    Sydney, Australia
    If you are asking a question on the same topic as an existing thread, then you should always use the existing thread (no matter how old), otherwise it'll probably be merged (especially if I remember the existing thread).
    I was just not sure if you realised the thread was a year old...
    Anyway - as I said last night, my first post was a bit full on, so I apologise.
  5. #25
    Sep 2010
    All good.
  6. #26
    Oct 2010
    Melbourne, VIC
    Quote Originally Posted by prise View Post
    All this is true but you don/t mention that this is happening over fewer piston strokes. Also the mass of the piston and connecting rod being accelerated up and down creates loads that increase with RPM. Golf diesel engines have a good reputation for longevity and they have been lugging at low revs and high cylinder pressures for years. It comes down to what the engines been designed to do.
    Another post to put in the "thread revival" category...
    Diesels are fabulous for lugging at low rpm due to the high cylinder pressure peaks, lack of throttling and the low bore/stroke ratio. All are inherent in the diesel cycle and also require the engine components to be far stronger than for a petrol engine of similar power output. This makes diesel engines pretty much immune to damage from side thrust loads on the pistons and bores.
    None of this is relevant when discussing the suitability of the TSI engine for lugging at very low rpms with large throttle openings. Idaho's point about side thrust is a very valid one given that the TSI engine is square bored, but without knowing other details of the engine internals (the con rod length, piston skirt length etc), we cannot know if sustained running at 1500 rpm with the throttle wide open will lead to premature failures.
    It is true that many small Japanese designed cars do suffer from premature engine wear when driven by young women due to excessive throttle openings at low rpm but the engines in these cases tend to be quite oversquare (and hence don't suffer unduly from high piston speed when driven for sustained periods at high rpm - crankshafts are another matter) as the Japanese like to chase high power outputs for the spec sheets. European cars are less prone to this as they tend to be designed more for real world driving so they are less highly tuned (in the non-performance versions anyway) and designed more for torque at low rpm than power at high rpm.
  7. #27
    Jan 2010
    State of Denial
    Happy to continue the revival.
    Quote Originally Posted by kaanage View Post
    I don't think anyone was talking about sustained running at 1500 RPM and WOT (at least I hope not for the next owners sake). The thread was about whether the DSG7 shifted up too early and I know that my DSG7 will shift down a gear well before then, however it will hold low revs under moderate throttle openings. Your points about the influence of con-rod length, etc are all good ones - it comes down to what the engines been designed to do.
    Out of interest - can anyone tell us what the conrod length on the 1.4 engines is?
  8. #28
    Aug 2009
    Melbourne, Vic
    ..we cannot know if sustained running at 1500 rpm with the throttle wide open will lead to premature failures.
    Ha.. That was the only line in the post that got my attention too. Sustained running at 1500 rpm with the throttle wide open is not readily achievable with the DSG7. With WOT it will downshift or the rpm will increase in the same gear. Either way the rpm will increase.
  9. #29
    Oct 2010
    Melbourne, VIC
    Please feel free to be disinterested, logger.
    OK, "sustained" was a poor choice of words. "frequent" may have been better to convey what I meant, which is regular high loading of the engine at ~1500rpm.
    The whole thread revolves around the noticably greater vibration of the engine when running with large throttle openings and when the DSG decides to shift up early. And while it may not be WOT, the throttle must be fairly open for the engine to load up enough for the engine mounts to be stressed in this manner. It may well be that the engine mounts are the items that are actually the most highly loaded rather than the engine itself.
    As others have also posted, I've found manually shifting later in these circumstances not only reduces the vibration but also the fuel consumption and increases acceleration so the DSG programming is not optimal in these situations. This makes the notion that "I do not believe the designers would allow them to so readily operate in a regime where it could damage itself" a bit of a leap of faith, in my book. Designers are people and in this world of mass production and cost benefit analysis, things can get missed - otherwise, there would be no such things as recalls.
    I'm not against shifting very early when the situation justifies it. With very light throttle openings (eg when accelerating only enough to keep up with traffic going down slight inclines), I actually find that the DSG won't shift early enough.
  10. #30
    Nov 2009
    Cromer, Sydney
    am fairly sure (without digging around for the article 'cause it is SUNDAY!) i read about the simulated testing done on the 1.4TSI engine.
    VW had engines tested to over 300,000 kms without too much drama. in fact i'm sure you'll find many a 1.4TSI in europe with kms close to this. whatever the case i understand the push for engineering to focus on fuel economy for marketing, and VW have achieved this while still throwing down some decent performance figures. congrats to them for doing the R&D and being the pioneers in bringing this engine technology to the masses. (has been used in trucks i believe, and some old school rally car--> name??).
    --- Dean Slavnich, editor of Engine Technology International and co-chairman of the International Engine of the Year Awards, said: “The international judging panel is hugely impressed by this VW engine. It’s a masterstroke of downsizing technology and a real engineering showcase. I have no doubt that this engine will become the template for a whole new generation of high efficiency, small capacity engines in the years to come.” ---
    lastly. isn't the 1.4TSI made from a cast iron block? ie: strong little bugger!?
    Current - MY16 2015 Octavia VRS Wagon 220 tsi DSG Corrida Red, tech, Leather, 18" black
    SOLD - 2008 United Grey GT Sport TSI DSG
