Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: Turbo needs replacing (wastegate)
    Quote Originally Posted by Mapko View Post
    VW told me that the wastegate was causing the problem and couldn't be repaired. This is what was on the invoice.
    Attachment 27027
    It might be causing a rattle but for 4K I'd live with it, get it tuned, with a downpipe, cat back exhaust, coilovers and still have change for great night at the casino.
    Apr 2016
    melbourne
    Haha, I like the way you think however I'm not looking to offload that much coin at this stage. Will a tune on its own suffice without the addons?
    Oct 2014
    Is the rattle from the turbo CHRA or the wastegate valve?
    If it's a worn out bearing on the turbo the shaft will wiggle when you try and move it with a hose off. In that case you can order a pre balanced CHRA (center housing rotating assembly) which is a fancy term of all the important insides of the turbo. Mellet in the UK make good stock replacement ones for a couple of hundred bucks. No idea what labour to install would be but it won't be $4,000 and I sure as sh$t wouldnt be visiting a VW $tealership after warranty for anything.
