![Quote](https://www.vwwatercooled.com.au/forums/images/misc/quote_icon.png)
Originally Posted by
Rocket
Isn't the limit for the 7sp box 250Nm? If so, are you not pushing it dramatically close to the limit at 238Nm everytime you hit the pedal and pass 2600-3600rpm in the twincharger?
250Nm is a rating not a limit.
eg: A crane might be rated at 1tonne but may have a higher limit/capacity engineered into it.
I don't think it's a coincidence that the 7 speed has a rating of 250nm and the torqueiest engine it is mated with (In the Skoda Octavia 1.8TSI - 118kw/250nm) outputs 250Nm as well. I would guess that after a while, when the 7 speed has proven itself, they will fit it to a "bigger" engine & surprise, surpise, it will be re-rated to suit the higher torque.
