Page 25 of 40 FirstFirst ... 15232425262735 ... LastLast
Results 241 to 250 of 393
Thread: TSI squeal noise problem on acceleration
  1. #241
    Perth
    Interestingly on my GT I had intermittent chirp or squeak between 10K & 20K km but in the last 10-15000km or so it hasn't made a noise, FYI I'm now at 37000km.
    MY08 Blue Graphite GT TSI DSG
  2. #242
    Feb 2010
    Hey coastie, I am curious if the water pump replacement has fixed the squealing noise. That is about a month ago when it was replaced.
    __________________________________________________ _____________
    2014 GTI PP/Pure White/DAP+Leather
    2010 TSI 118/DSG/Reflex Silver/SP+ACC/Sunroof/Dyna/MDI/SatNav /PA+RVC
  3. #243
    Oct 2009
    Melbourne, VIC
    jumping in a little late here but my experience is of a 5000 kms old 118 TSI that delevoped the much talked about "squeak" - just as the SC kicks in. Took the car for a drive with one of the guys from the service department at Essendon and he comfirmed the noise came from the water pump / supercharger clutch assembly - known issue. Anyway the pump has been replaced under warranty with a revised version so I hope thats that. Other than that, the car has been great
  4. #244
    Jun 2006
    Sunshine Coast
    Quote Originally Posted by ctan View Post
    Yes no more noise, the car is great 2300km further since the replacement. It has just had its first birthday and I still feel like I'm driving a brand new car. The car has over 25000km.
    2018 Skoda Superb TDI
    2010 Skoda Superb TDI
    2009 Golf VI 118 TSI
    2006 Multivan TDI SOLD
  5. #245
    Jun 2006
    Sunshine Coast
    Quote Originally Posted by logger View Post
    I dont mind the Squeak either.
    ".....explain to the customer that this noise is normal and that no damage to the solenoid clutch will occur after the warranty period."
    (from the VW Technical Service Handbook)
    Just hypothesising but if there is a release of noise then there is a loss of energy and frictional loss creates wear as indicated by the noise. Consider that your tyres made a chirping noise due to slip on the road each time they took off. (not that that has ever happened) We all know that this is wearing the tyres faster than if they were to grip and not make any noise.
  6. #246
    Aug 2009
    WA
    According to German magazine Auto Bild and some forums new pump is not fixing squealing noise as it was expected.
    This is translation from Auto Bild:
    Google Translate
    MY16 GTI 40
  7. #247
    May 2010
    Bundanoon NSW
    Can appreciate concern re this clutch. got me worried too.
    Hope my MY11 build will be better.
    However, clutch MUST have some slip on engagement.
    Consider dry clutch system in DSG. Quite possible also makes slight noise on engagement, but not audible, due to being inside housing.
    Do not know design of clutch, but consider it possible magnetic system used to disengage, rather than engage.
    In which case, if magnetic area made from ferrite (Ceramic) this is extremly hard surface. EG, chirp not due to metal on metal 'spalling'
    MY13 Passat 130TDI Sedan. Autumn Brown Metalic, Desert Beige seats. Sat nav, Rev camera, Dynaudio, 12way adj seats. No ACC Previous Golf 118 TSI with ACC given to my son
  8. #248
    Manly - Sydney
    Haha, agree totally, the more sounds thre better!!! Go Golf!!!
    Stoney!
    6 Sp Manual 118 TSi
    Colour: United Grey
    Build Date: August 09 Delivery Date: 16th Oct 09
    ODO at last fill: 2555km
    Avg Fuel Cons at last fill: 8.6
  9. #249
    Jan 2010
    State of Denial
    My TSI is making the noise occasionally with the colder weather so I had a look at what the VW erwin database had to say about the noise for my VIN last weekend. Bottom line is that it is a recognised fault, they have made a production change and there is a part replacement you can get done under warranty if you can demonstrate the noise to the dealer. My last car (Mazda 6MPS) had a diff harmonic at a specific road speed and Mazda decided to do nothing and tell all the owners it was a normal characteristic of the car so it's good to see VW being proactive in this instance.
    Here's an abridged version of what they had to say:
    Description:
    Clear, brief, high frequency squeaking noise.
    Technical background:
    As the water pump builds up with solenoid clutch, the one piece anchorage plate on the outer pulley starts to vibrate. The volume of the noise depends on the operating conditions.
    Production Change:
    Improved water pump with solenoid coupling from engine no.
    CAV* 154 174
    Measure: (I've omitted the bit about stationary testing as it can't be performed with DSG's which most of us have)
    1. Constant speed in 2nd or 3rd gear at 2000-2200 rpm
    2. Brief acceleration (1 second)
    3. Repeat a few times
    With engine codes BMY, BLG, BWK, CAV* fit the water pump with solenoid coupling with part number 03C121004 J.
  10. #250
    Guest Guest
    Quote Originally Posted by prise View Post
    Description:
    Production Change:
    CAV* 154 174
    That TPI has been out for about 2years now!
    Also the new water pump is still not fixing the noise on some
    They are testing a new compound at the moment
