Results 1 to 10 of 11
Thread: Tool to cut hole in MK6 center stowage?
    Aug 2009
    Melbourne, Vic
    I posted over in the Audio section, with no response. Hoping someone around here might have a suggestion. I need to cut a hole in my center stowage of my Mk6 to fit one of these
    where the coins are below..
    Access is limited on both sides by the shape of the stowage, so a hole saw is out of the question. Ideally I would like a nice neat hole and not a hacked out job.
    What sort of tool should I be using to do this?
    Point Cook, Vic
    id use a dremel. One of the best tools ever invented
    mark the outline of your hole. drill the centre out and then slowly remove material up to your guide line. Should only take a minute or two. Be careful dremeling plastic too fast though as it will start to melt it if you rush too quickly.
    FOLLOW US ON FACEBOOK
    Feb 2010
    just use drill and work your way from small hall to a larger one ...
    His: Golf6 5door GTI DSG Carbon Sunroof MDI and 18" Drag rims + sticker that gives extra horse power
    Hers: Skoda Kodiaq Tech/Lux pack and sunroof
    Aug 2009
    Melbourne, Vic
    Thanks fellas. Will give it a crack.
    Sep 2009
    Perth, WA
    +1 dremel. Work slowly from the centre like Tim suggested though because they can get away from you very quickly.
    GTI MKVI Candy White | 5 door | DSG | ACC | 18" Detroits | Leather | Electric Seat | Sunroof | RNS510 | Dynaudio | Park Assist | RVC | MDI
    This:
    this:
    Feb 2008
    Richmond, VIC
    One of these???
    Seriously though a dremel is jhard to beat for these things, can buy a cheapo version from bunnings for pocketchange too.
    currrently... MY10 GTI | DSG | Candy White | Sunroof | 18's | BT | MDI
    previously... MY08 GT TDI | DSG | Reflex Silver | Sunroof
    Mar 2008
    Chatswood, NSW
    Hi Logger, where abouts did you get that USB attachment and can it be connected to just a regular mk5 head unit?
    MKV GTI
    Aug 2009
    Melbourne, Vic
    Gee guys. Flooded with good responses. Thanks for all the suggestions/tips.
    Jessv3, from ebay, just search for "belkin micro usb". It is designed to fit flush into a 12v lighter outlet and convert it to USB 5v 1a. However my intention is to solder a lead onto the end of it and connect it to the fuse box with a fuse tap. Thereby giving me a 5v outlet beside the AUX audio input. Others have done similar by starting with a standard 12v to usb power converter and butchering it. Like this USB Port - Imgur But I reckon that looks pretty crappy. There are also cheaper micro plugs than this one but the are only 500ma.
    Because this Belkin jobby is so compact, I hope it will provide quite a professional neat look that wont look like it is tacked on. Not sure why you would want to connect it to a head unit? Oh I see - perhaps you were thinking it is for USB data. No it is only fro USB power.
    Mar 2008
    Chatswood, NSW
    Quote Originally Posted by logger View Post
    whoops sorry, i thought it was some cool new media device
    MKV GTI
